heater core
Old Oct 9, 2006 | 12:29 AM
mt vernon's Avatar
mt vernon
Default heater core
I was wondering if anyone would have a diagram or instructions on how to replace the heater core on a 1998 ram 1500 4x4 5.2L. any info on this would be appeciated.
Old Oct 9, 2006 | 12:40 AM
lukeshupe's Avatar
lukeshupe
Default RE: heater core
I was kinda wondering the same thing, but as far as I could tell you have to pretty much remove the entire dash. It seemed pretty involved to me. I asked one of my mechanic buddies about it and he said its listed as like a 6 hour job. Hes gonna do it for me in his shop for around $300, I decided it was worth that beacuse I know I would surely get frustrated. I know that doesn't help with your question I just thought I would add my two cents.
Lucas
Old Oct 9, 2006 | 12:49 AM
DieselDemon's Avatar
DieselDemon
Don't fret men.......LOL. Don't quote me, wait till a pro signs on here but, I am pretty sure you can "tilt" the dash forward, and have enough access to the core. Someone will confirm or deny shortly.......LOL.
Good luck.
Old Oct 9, 2006 | 01:32 AM
cumminsgetsome's Avatar
cumminsgetsome
I just done mine last week I had been dreading it for a month or so but it only took me a two hours, now mine is a 97 but should not be to much different. I just took the dash loose and put a bungee cord to the passenger side upper grab handle and pulle the dash back then dissconnected the a/c hoses and heater hoses. there is a couple of wire plugs that is right behind the glove box that need to be unhooked and the hose/cables from the heater switchs also need to be unhooked but all the other wires in the instruments I left in place. I probably forgot something that needs to be disconnected but it is quite simple as far as heater cores go. I have done lots that were worse.
Old Oct 9, 2006 | 04:07 AM
Ramdamit98's Avatar
Ramdamit98
I haven't had to do it in a 2nd gen Ram yet (cross my fingers), but I've done it in plenty of other vehicles in when I worked in a radiator shop and if it's listed as a 6 hour job then anyone with decent mechanical skills, a shop manual should be able to do it in 3 hours. Not to say it wouldn't be a headache but we used to be embarassed to charge someone 7 hours labor to re and re a heater core on a Suzuki Samari (for a $50 part). Just watch out it's really easy to pinch the vacuum lines and not have your vents work properly.
Old Oct 9, 2006 | 08:22 AM
lukeshupe's Avatar
lukeshupe
I figured with some know how and a little expreirence it could be knocked out pretty easily. I just flet better sending it to the shop so I know its done right, I wouldn't wanna have to go back in there besides, I got really frustrated with it on Saturday and I knew if I kept fooling around I would probably be able to do it, I'd judt tear up something else in the process. Yeah spending 300 dollars on a 80 dollar part stinks but, atleast I know it will be fixed now.
Lucas
Old Oct 9, 2006 | 02:20 PM
Ramdamit98's Avatar
Ramdamit98
ORIGINAL: lukeshupe
Lucas
Yes there are definitely times it's just easier to take it in and not have to deal with it.
Old Oct 9, 2006 | 05:27 PM
t_willy's Avatar
t_willy
check out the merry Xmas post - it has the 2001 ram service manual - not sure where it's at now but it shows all the connections etc from all sorts of angles.
Had mine changed out last Nov - dealer would have charged me between $800 - $1000. Glad I got the warranty plan.
I had to pay $100 deductable and an extra $130 bucks for a cooling system flush and fill since I tried to fix the heater core on my own with a bottle of stop leak or bar's leak or something.
BTW - DON'T use the radiator leak sealant crap!! 1. It doesn't work and 2. It makes the coolant look like vomit so when a mechanic looks at it he thinks you've severly neglected that system - cost me an extra $130 so he wouldn't tell the warranty company I had jacked up the core by not doing regular maintenance etc...
Old Oct 9, 2006 | 06:19 PM
Mayfair's Avatar
Mayfair
I'm just curious as to how do you know when your heater core is shot ?
Old Oct 9, 2006 | 06:46 PM
2001ramsport's Avatar
2001ramsport
by the puddle of antifreeze on the floor?
