Installing shorty headers
Old Oct 11, 2006 | 12:28 PM
nihlcat's Avatar
nihlcat
Default Installing shorty headers
I want to upgrade to Gibson shorty headers (PN GP301S), but wanted to get some expert advice before I commit to purchasing. I wasn't able to find all of this info searching the 2nd gen section.
I really want to do the install myself. Can this be done without a lift?
Are there any majot caveats to installing them? I see that leaks are a common issue.
I read horror stories here about headers rusting out in under a year. Do the stainless headers have a long lifespan?
Old Oct 11, 2006 | 12:46 PM
jram99's Avatar
jram99
Default RE: Installing shorty headers
nihlcat, I've heard the Gibson stainless are some of the best you can get. Expensive, but will last. If you can afford the stainless with the coating even better. I have a set of cheap Summit headers but haven't put them on yet. I haven't decided if I just want to go ahead and get the Gibson stainless and do the job one time or if I want to put the Summits on and see if a noticable difference before I spend the money on Gibsons. I've also heard that using a copper gaskets is the best way to go, but since I haven't put mine on yet someone else here may have a better information.
Old Oct 11, 2006 | 01:35 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
There are a few threads in the forums about shorty headers. Gibson are rated the best, and Summit receives bad marks. A lift is not needed to install them.
Old Oct 11, 2006 | 02:30 PM
steve05ram360's Avatar
steve05ram360
yeah the gibsons rock and are a piece of cake to install... the toughest part is yanking out the old studs out of the head. soak them real good with pb blaster or liquid wrench, put 2 nuts on it, tighten them together and wrench off the inner nut. the stud will come right out.
Old Oct 11, 2006 | 02:34 PM
GOD RAM IT's Avatar
GOD RAM IT
the other pain is the last bolt on the passenger side and the last 2 bolts on the drivers side.
all of them need to be tightened from under the vehicle and they are a pain.
or at least they were for me. But all in all it was pretty easy.
Just make sure you get quality gaskets, like Mr. Gasket
Old Oct 11, 2006 | 02:57 PM
Brad426's Avatar
Brad426
I found them easy to install. I cut the flanges between the two center pipes and each of the outter pipes to allow the mounting flange to flex and reduce warpage. It works quite will. I bought a set of mechanical locking header bolts and copper HP gaskets on e-Bay for a song. Just do s search under exhaust parts, Dodge 360. My headers we run for a year. Removed. glass beaded, cermachromed I high-temp powder coated flat white. I have yet to run them in and I'll let you know how yey work out. I think they will be fun to keep white.....
[IMG]local://upfiles/41527/DBE441D6E9224E279E17DA2B87FEFC90.jpg[/IMG]
Old Oct 11, 2006 | 03:28 PM
GOD RAM IT's Avatar
GOD RAM IT
of course its super easy if you have the motor out of the truck.
Old Oct 11, 2006 | 07:26 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Brad426
Tell me more about those valve covers. What did they run you, and do they have the baffles like stock?
Old Oct 12, 2006 | 01:41 AM
turbot_bird's Avatar
turbot_bird
I had some gibsons on my 01 ram 5.9 they where nice. sold them on here a few months back.
Old Oct 12, 2006 | 02:05 AM
timwag2001's Avatar
timwag2001
i had a bitch of a time getting the stock manifold off. i gave up after a while and took it to lous custom exhaust. let them deal with it. i got ceramic shorties and they started to just in 2 years. especially on the flanges.
