fog lamps
Old Oct 17, 2006 | 06:22 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default fog lamps
Im thinking about getting some foglamps. Where would i be able to find da good set? and how hard are they to wire in. I have very little expereince with electrican work.
Old Oct 17, 2006 | 07:17 AM
habeba86's Avatar
habeba86
Default RE: fog lamps
Do you already have foglights and you are jst changing them or do you not have any at all?
Old Oct 17, 2006 | 12:36 PM
DieselDemon's Avatar
DieselDemon
Make sure everything is FUSED and RELAYED.
Take the foglamp power directly from the battery.
Good luck.
Old Oct 17, 2006 | 05:39 PM
JarheadX's Avatar
JarheadX
Fog Lights are the best lol. I love them.
Old Oct 17, 2006 | 07:24 PM
Sinister's Avatar
Sinister
Foglights are simple to install.
the hardest part is deciding what style you want, and the CPoutput.
wiring is simple (12gu wire is best), ground the light at the light if at all possible, or as close as you can.
run your wiring from the light to the switch, though the firewall.
run your power wire from battery (including a 20-25amp fuse 6-8" from battery) through the firewall to the switch.
Ground switch under dash somewhere.
test.
congratulations you have just installed your first set of foglights.
Old Oct 17, 2006 | 07:59 PM
dillonjm's Avatar
dillonjm
ORIGINAL: Sinister
test.
That's not the best way to wire up foglights. You should run a relay for them.
IE:
Old Oct 17, 2006 | 08:17 PM
Sinister's Avatar
Sinister
ah the relay.. lol., my lights had a relay built into the wiring. so the lights both just plugged into the one., dont most lights have that?
Old Oct 18, 2006 | 12:35 AM
dillonjm's Avatar
dillonjm
None of the lights I've gotten have had relays built in. But maybe mine have been the exceptions.
Old Oct 18, 2006 | 07:57 AM
Zeppelinrocks
thanks for all the help, i need to find some oem ones now, by the way whats a relay? and what do the three lines next to each other on the diagram mean?
