leaf spring block lift ?
ok i just put the 2" coil spring spacer's on the front of my truck and now the front and back wheel wells measure the same. butt it looks like the front of the truck is setting higher than the back it could just be the body lines or somthing butt i dont like it. what is the easy way to lift the rear end about 1" ?
You should be able to go to AutoZone or Advanced and get universal lift/lowering blocks. I'm not sure if they come in 1" or not, I know they have 2" though. You might be able to get some kind of add a leaf setup too.
Buy an Add A Leaf from Summit or JCWhitney. They are $45 bucks. Using a block is more expensive and will create more axle wrap than you already have
or you spend a little more and get them from Skyjaker and have a little better ride
ORIGINAL: JD770
when lifting, avoid blocks.
rule2 avoid any bodyl ifts over 1"
3"s is the max on full size rigs
ORIGINAL: GOD RAM IT
Rule 2 applys to Jeeps and other short wheel based vehicles.
ORIGINAL: JD770
Trending Topics
ORIGINAL: JD770
I wouldnt ride on 3" of hardened poly on any vehicle.
ORIGINAL: JD770
and in all actuality it doesnt raise the center of gravity as much as a suspension lift does.
Now, If you were talking a home made one then yes I would agree.
ORIGINAL: silverram99
