Which ATF do you run?
Old Oct 30, 2006 | 04:45 PM
dillonjm's Avatar
dillonjm
Default RE: Which ATF do you run?
Around here Napa and Oreilly's both carry ATF+4.
Old Oct 30, 2006 | 04:48 PM
steve05ram360's Avatar
steve05ram360
Mopar ATF+4 all the way... I got a deal on a case from walmart... $3.40/qt
Old Oct 30, 2006 | 06:14 PM
jf1000's Avatar
jf1000
I've heard it is not safe to run ATF4 in a transmission that has already had atf3 in it. Any truth to this?
Old Oct 30, 2006 | 06:19 PM
steve05ram360
nope, IIRC atf-4 is compatible with atf3... started doing the atf-4 swap during the last service on the 2000 before selling it. the tranny shop owner said there was no problem and they were compatible.
Old Oct 30, 2006 | 08:11 PM
bamory's Avatar
bamory
ATF 4 is recommended for all Chryslers now
Old Oct 31, 2006 | 05:03 AM
bcdalton's Avatar
bcdalton
I use Mopar ATF+4.
Old Oct 31, 2006 | 11:40 AM
Ram Man 98's Avatar
Ram Man 98
I got the ATF+4 from Dodge. They also said I should change the gasket on the pan, so they set me up with a plastic gasket & filter. Should be good to go, thanks boys
Old Oct 31, 2006 | 06:18 PM
DPR250R's Avatar
DPR250R
I first serviced my trans with Dexron III in 2003. Since then I have changed the filter and fluid twice with Dexron III.
I did this before finding this site and I went by what was written on the dipstick. I work at a Chevy dealer so it was easy enough for me to use Dexron.
I have put at least 30,000 miles on my truck since the first change. I have also added a Flex-a-Lite cooler.
My trans has been great... so great that I am afraid to put ATF+4 in it....
I am going to switch to Mobil 1 Sythetic sometime soon...
Read my sig for my truck specs....
Good Luck with whatever you run...
Old Oct 31, 2006 | 06:57 PM
shott8283's Avatar
shott8283
ORIGINAL: junkman306
I use dexron 3.
dexron isnt compatable with mopar trannies... alot of dodge owners use it for some reason,, some make it ok with no problems.. others tend to have alot of problem..
currently im running Vavoline full synthtetic ATF+4.. and infact your "saposed" to be using +4 in all dodge trannies.. IIRC there was a TSB out that suggesting the swap.. but +3 is still fine to use and starting to be a bit cheeper.
Old Oct 31, 2006 | 10:02 PM
dodgerules86's Avatar
dodgerules86
ORIGINAL: shott8283
TSB 21-010-06
All Ram trucks from 1989 on are recommended to be filled with ATF+4. (And if the owners manual states to use ATF+4 DO NOT use anything else). ATF+4 is backwards compatible with all previous versions, but previous versions are not forwards compatible.
And shott8283, you like the Valvoline? I'm gonna be swapping my trans fluid in December, and was just wondering if ya like it.
