Runs rough for few minutes then smooths out
Old Oct 30, 2006 | 08:01 PM
TROUTMAN's Avatar
TROUTMAN
Default Runs rough for few minutes then smooths out
I'm having a problem with my 2000 Dodge RAM 1500 5.9L. It idles fine for about a minute and then starts running very rough, almost sounds like it is going to quit, After about 2-3 minutes, it will smooth out and runs fine until you turn it off for i'm guessing 20 mins or so. I have cleaned the IAC plunger. It makes a loud vaccum sound for a few seconds when i am guessing the IAC is wide open then closes back down. Any ideas?
Old Nov 1, 2006 | 05:37 PM
TROUTMAN's Avatar
TROUTMAN
Default RE: Runs rough for few minutes then smooths out
I'm new at this ....... anyone see this or did i enter in the wrong place?[sm=americanasmiley.gif]
Old Nov 1, 2006 | 07:52 PM
crazy1snow's Avatar
crazy1snow
sounds like you have a vaccum leak going on. hard to find... don't even know where to tell you to start looking other than tha IAC area. (that's the area you messed with) could just simply be a loose hose. or a broken one.
Old Nov 1, 2006 | 10:09 PM
silverram99's Avatar
silverram99
Take a can of carb cleaner and spray it around the base of your throttle body. As you do that listen for the idle to change, if it does focus on the area you were spraying on when it changed. Shouldn't be too hard to find then, but those vacuum leaks can really kick your *** if you aren't careful.
Old Nov 2, 2006 | 12:36 PM
TROUTMAN's Avatar
TROUTMAN
OK, thanks for the tips, i'll check it out.
