Front Drive Shaft Question on a 4X4
Old Oct 31, 2006 | 10:40 PM
dillonjm's Avatar
dillonjm
Default RE: Front Drive Shaft Question on a 4X4
It won't be. If it's not spinning it won't make noise if it's a d-shaft u-joint problem.
If you still think it's U-joint or in the CV style joint at the t-case side just remove the 8 little bolts (4 on the axle yoke, 4 on the t-case front output). If it stops then it's driveshaft related. If it doesn't, look elsewhere.
Old Nov 1, 2006 | 01:41 AM
DieselDemon's Avatar
DieselDemon
Usually the front drive shaft doesn't spin in 2wd. It can however. Make sure that your shift fork/collar isin't engaged. Is the differential full of fluid? Guys run them dry or with a low fluid level. Things heat up and now because of expansion, the carrier turns with the side gear, and that spins the drive shaft.
Maybe you have a bad wheel bearing?
Good luck.
Old Nov 1, 2006 | 01:45 AM
05SilverHemi's Avatar
05SilverHemi
Did you check the front axle shaft u-joints? Mine were making noises as they were both smoked. The front axles spin regardless if the truck is in 4wd or not.
Old Nov 1, 2006 | 02:16 AM
moparrtguy's Avatar
moparrtguy
I will check the differential fluid level tomorrow. I have an appointment to have the drivetrain checked on Thursday, I will have them check axle u-joints and wheel bearings as well. I will also see if removing the driveshaft makes the noise go away. I will post updates - thanks again!
Old Nov 2, 2006 | 09:15 PM
moparrtguy's Avatar
moparrtguy
UPDATE: I got my truck fixed today and here is what they found: All u-joints are good. Squeal coming from left outer axle tube seal. Cleaned, adjusted, and lubed. Fixed the problem.
Old Nov 3, 2006 | 12:48 AM
dillonjm's Avatar
dillonjm
Glad you got it figured out.
Old Jan 7, 2011 | 04:36 PM
Wickedwiggles's Avatar
Wickedwiggles
Default Squeal and front driveshaft removal
I have a squeal coming from my front d shaft. I can get under the truck and spin the shaft and make it squeal. I am almost positive its the u-joints. However the problem is the four bolts at the t-case that I can't get to budge. Are they reverse threaded or is there any trick to getting them off? I pb'd em and heated em and pounded on em and not a budge.
Old Jan 7, 2011 | 04:39 PM
Normal threads, they just hang out in an icky (technical term) environment, and hang on VERY tight.
I just put the t-case in 4-lo, to lock it in place, a breaker bar that was almost too long to get a good swing..... to get 'em off. It was fun, but, it worked.
Old Jan 7, 2011 | 04:44 PM
Wickedwiggles
Did you take off the skid and tranny brace to get em with a socket or just used a wrench?
Old Jan 7, 2011 | 04:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The easiest way to get the bolts off is to disconnect the ujoint from the diff first. This way it will swing out of the way enough to get a socket and extension on the lower bolt. Rotate the shaft and repeat. Putting it in 4wd after each rotation works as stated, but an impact works even better.
