custom bumpers
Old Nov 1, 2006 | 03:18 PM
CopperDesigno's Avatar
CopperDesigno
Default RE: custom bumpers
Being totally water tight isn't a big concern. All that would be in it is an old shovel, some chain and rope. Nothing I would care about if it got smashed in a accident.
My idea was to glue door weather stripping to the edge of the plating that made the vertical sides of the box.
Old Nov 1, 2006 | 05:04 PM
GOD RAM IT's Avatar
GOD RAM IT
yeah but if it gets dented then how will you open or close the bumper?
That and it wont look to puportionate to the truck if you want to fit a shovel in it.
I guess I would just prefer to keep everything in the bed.
Old Nov 1, 2006 | 05:11 PM
GOD RAM IT's Avatar
GOD RAM IT
I forgot that someone on PS.com had started to make one.
But if you look at it, there is no bracing. so the smallest hit from the rear would put a decent dent in it and make it impossible to close
Old Nov 1, 2006 | 07:56 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
thanx guys...... any suggestions anyone might have? i dont want anything as elaborate as the first picture, but the second to last one looks a little too plain....... but it probably helps approach angle.........
haha i wish i had the money to have to make room for a winch but i guess that wont be an issue.
also the second to last one doesnt APPEAR to have any tow points........ quick question. I'm gonna have tow hooks on the front bumper; should i weld them on, or bolt them onto it?
Old Nov 2, 2006 | 12:20 AM
crazy1snow's Avatar
crazy1snow
bolt and weld... stronger.. or if you just bolt it use grade 8 bolts. use 3/8-1/4 inch steel. strong enough to take pretty much any impact. good for welding too. i'd use 1/4 for the main parts like braces and bolt points and use the 3/8 as filler flat pieces
Old Nov 2, 2006 | 12:31 AM
muddy_blue_dodge
ORIGINAL: crazy1snow
i probably will have very little metal sheets, mostly bars.....
Old Nov 2, 2006 | 12:34 AM
crazy1snow's Avatar
crazy1snow
hmm missed that.. then i'd go for at least 1 inch diameter pipes. bars would be REALLY heavy... just a bit of metal selection difference.
if you do order stuff go to a steel shop and ask for their "scrap" stuff. usually you'll be able to get it a HELL of a lot cheaper than ordering online.
Old Nov 2, 2006 | 12:49 AM
Socha_62's Avatar
Socha_62
I agree, bolt and weld Grade 8 is the only way to go.
Old Nov 2, 2006 | 01:32 AM
muddy_blue_dodge
this should be a fun project....... my buddy has the welding skills and hes gettin a welder soon...... so hopefully it should go as smoothly as possible
any other thoughts??
Old Nov 2, 2006 | 01:42 AM
muddy_blue_dodge
ok i just thought of a question
when i take of my old (stock) bumper, should we cut off the bumper mounts and use them for the new custom bumper? or should we make new bumper bracket mounts for it? or does that even matter?
