Do any programmers remove torque management?
I've looked through detailed wiring diagrams of the ECU and have never see anything about the TM system. I'm gonna do some more check on it though.
It's internal to the PCM (in the mode programming), so a wiring diagram probably wouldn't show anything. Torque management occurs when the PCM goes into Wide Open Throttle Mode, which is one of nine seperate modes that the PCM recognizes and has specific programming for. Once you enter Wide Open Throttle Mode, the PCM manages torque application by pulling ignition timing based on inputs it is getting from various sensors. Basically, it looks at the vehicle speed, rpm, auto tranmission gear selection, and other sensors inputs (MAP and TPS namely), and using a predifined algorithm, determines when to pull timing, which it does by turning the ground path to the coil on and off.
Oh, and incidentally, one of the inputs that is used to determine if timing is going to be pulled or not is the coolant temp. This is why torque management feels much worse when you are operating at max coolant temps (like when the ambient air temp is high and your engine is running with the t-stat open, or you are hauling a load or towing and your coolant temps are high, or your off-roading and the engine is at max operating temp).
This is one advantage of switching to a 180 tstat in my opinion.
I didn't wanna start a new thread on this but i was wondering what "torque management" is? From reading this post it sounds like it is the Stock PCM limiting the amount of torque/hp that the engine will produce but only at wide open thottle........Why would that be done? i am assuming it is mainly at low speeds?
It was my impression that Torque Management first showed up on the 45RFE and 5-45RFE transmissions and the 4.7 and especially 5.7 V8s.
I have never read of TM being used on the 3.9/5.2/5.9 V8s and the 46RH or 46RE series.
Trending Topics
ORIGINAL: Spartan
Why would that be done? Several reason I think, but mainly I think it is their attempt to extend the life of the drivetrain components. Limiting the amount of timing advance essentially keeps the full torque potential of the engine from being applied to the drivetrain all at once. This should, in theory, extend the life of your transmission, transfer case, driveshaft components, differentials, and also helps prevent overheating and excessive stress of the engine components. Another reason I think it is done is for fuel economy. Slowing working into the timing curve requires less fuel then a fully advance timing acceleration. Lastly, it is for generic public driveability. Without torque management of some sort, accelerations can be jolting (at least to the average driver who cares nothing about performance). TM eases the transfer of torque to the drivetrain more smoothly. Same reason auto transmission have extended shift slipping times- to slowly transfer energy to the wheels. To bad this actually generates excessive heat and decreases transmission life in the process, but hey shifts are smooth, so that is all that Joe Shmo consumer cares about.
ORIGINAL: HankL
