K&N FIPK No More
Old Jan 9, 2007 | 05:25 PM
  #151
ASH's Avatar
ASH
Default RE: K&N FIPK No More
Here's a picture of mine. Looks like I had to zip-tie mine up also. Very tight fit. Install the filter and base together, thread the S-bolt in, then slide the lid on. It drags the wiring harness and bolt until it drops into place over the filter. There should be clearance after you're done.
Nice port job on the TB. Did you do that yourself?
Old Jan 9, 2007 | 05:29 PM
  #152
ripto's Avatar
ripto
Ok I will take a look at it again and see where I can zip tie things.
Nah would be pretty cool if I did do it myself, but its the fastman TB
Old Jan 9, 2007 | 05:52 PM
  #153
ripto's Avatar
ripto
Ok well nevermind about the wiring harness, the filter is too big for my truck. I got the base and filter on but it was snug up against it, no way the top would be able to fit on. I'm gunna have to get a smaller filter.
Old Jan 9, 2007 | 08:32 PM
  #154
erikb45's Avatar
erikb45
i did the exact one thatsilver did and i am running the paper filter that came with it. no increase of MPG.! it does make a annoying whistling noise of air. it was really annoying untill i swithched to 3923's by autolite and some of it went away. i hear it more when she's cold in the morning then fades a little bit when she warms up. any ideas whats happening? the plugs deffinately seemed to have helped. my mpg is 11.69 - 11.79 everytime, highway,75 mph, not as good as others but super consistent. any ideas.
oh yeah like i said before this mod was awesome for power
Old Jan 9, 2007 | 09:54 PM
  #155
Silver_Dodge's Avatar
Silver_Dodge
Make sure you have the rubber gasket between it and the TB. Any filter that is this close to the firewall is going to be noisier then the stock setup. Mine is also louder in the morning until the TB opens up after warm-up mode. It doesn't whislte though.
Old Jan 9, 2007 | 10:16 PM
  #156
ripto's Avatar
ripto
Silver, you have a flat base right? What is the height of your new K&N, I don't think you mentioned it, I know you said the possible heights but don't think you said the one you have now. I have to go with a smaller filter, I don't know why this 3" won't fit in my truck.
For everyone, are the bottom parts of your base curved in? Mine is like an L shape around the bottom, the part that sits on top of the gasket on top of the TB, doesn't seem like it makes a good seal.
Old Jan 9, 2007 | 10:34 PM
  #157
Glideman88's Avatar
Glideman88
ORIGINAL: erikb45
I think almost 12 mpg at 75 mph isn't too bad, especially with the 4.10 gears in your Off-Road.
I used to commute over a 100 miles a day (all Interstate highway) and noticed a big drop in fuel mileage (1.5 - 2 mpg) atany speed over 70 mph.
Old Jan 9, 2007 | 11:28 PM
  #158
erikb45's Avatar
erikb45
i guess ts not a whistle more like when the flapper is closed on a carb, that sound of air rushing in.
and this tank ill try to stay under 70 and see what happens. lata
Old Jan 10, 2007 | 01:44 PM
  #159
ripto's Avatar
ripto
Here are some pictures of my AC maybe its not a flat base after all, I'm not sure. Just seems weird that when I had the base and filter on the TB, the top of the filter was snug against the truck, not even the wiring harness. Might just go for the 1480 Mr. Gasket with a 2.5" filter.
[IMG]local://upfiles/21486/D6108B3EF95C4015975D0ABFE3090D0B.jpg[/IMG]
[IMG]local://upfiles/21486/F9759BF3824C4E43BECC59A14E051A7A.jpg[/IMG]
[IMG]local://upfiles/21486/606FE15687E842C8BA8D7F2FF0212BAD.jpg[/IMG]
Old Jan 10, 2007 | 02:06 PM
  #160
Glideman88's Avatar
Glideman88
How tall is the filter you have right now?
