K&N FIPK No More
Old Mar 21, 2007 | 12:35 PM
  #251
HankL's Avatar
HankL
Default RE: K&N FIPK No More
Since you believe it made your MPG go up from 11 to 13
why not take it back off
and see if your MPG goes back down to 11 again?
My experience carefully watching 9 tanks of gasoline
on a 2nd Gen Ram is that the MPG will naturally
'jump around'
at least by 2 MPG
and you can't depend on tank to tank to tell you if something is an improvement:
old post
Here's the results of several tanks of gasoline I kept track of with the OD
either on or off in city driving. After each tank fill up, I alternated
keeping the OD on or off.
I have since made 3 more 300 mile long mpg tests in city driving since i
posted the original 6 tests. My test results now look like this:
OD turned off runs:
7-19-00 14.32 mpg Amoco87
7-29-00 15.17 mpg Amoco87
8-08-00 14.23 mpg Amoco87
9-08-00 13.53 mpg Amoco87
average 14.31 mpg
OD turned on runs:
(these were run inbetween the runs above)
7-12-00 14.16 mpg Exxon87
8-17-00 14.25 mpg Amoco87
8-24-00 15.49 mpg Amoco87
9-01-00 15.03 mpg Amoco87
9-12-00 14.35 mpg Amoco87
average 14.66 mpg
As you can see, so far the OD on/off difference seems to be small with a
slight 0.3 MPG edge to leaving OD on while in city driving. That is about a 2%
difference.
Note also how much the MPG jumps around. All realworld tests have 'random
variation.'
If I had done just two tests, and had by chance gotten the low 14.16 for the
OD on, and the high 15.17 for OD off, I would have falsely concluded that OD
on really hurts in city driving.
To get more reliable MPG numbers for Rams in city driving you need to do
multiple tests in a before/after/before/after sequence. Even better would be
to do SAE/TMC type IV testing with two or more vehicles following one another
'convoy' style.
Old Mar 21, 2007 | 04:04 PM
  #252
bamory's Avatar
bamory
Installed mine today, other than the noise didnt really notice difference but only went up and down road, sure does look pretty though.
Old Mar 21, 2007 | 04:29 PM
  #253
Silver_Dodge's Avatar
Silver_Dodge
Reset your PCM, then give it a hundred miles or a little more.
It's not going to give you a huge perfomance gain, but for me, with my mods, it was noticable.
Old Mar 30, 2007 | 03:07 AM
  #254
JarheadX's Avatar
JarheadX
I just got mine today, now im just waiting on my 33's to get here
Old Mar 30, 2007 | 04:14 AM
  #255
OlsenG_360's Avatar
OlsenG_360
I put on an Edelbrock Pro-Flow #1221 w/ 14x3" filter today. I couldn't believe the difference in throttle response and how quickly the RPM's climb now. Truck feels like a whole new beast, that tiny stock box must have really been choking the engine.
i picked up a set of mr. gasket adapters/spacersas well &neededto usethe 1/2" tallone. the hardest part was making the S-bolt and moving the wiring harness out of the way (i just clipped the zip ties & pushed the harness farther back into the engine bay, now behind the air cleaner, still has plenty of slack in it)
i did hook up the breather hose into the new intake,but the hose rippeda little while pushing it onto the fitting.i decided i'm going to cap off the fitting & run a standalone breather for less hassle.
i'll try to get a couple pics up tomorrow.
Old Mar 30, 2007 | 01:54 PM
  #256
TMS Bill's Avatar
TMS Bill
ORIGINAL: JarheadX
Hey, man ... excellent idea highliting the danger areas and caution warnings ... I'd of used RED but that is WAY cool.
Old Mar 30, 2007 | 06:03 PM
  #257
tinyfxds's Avatar
tinyfxds
How much are the round air cover/filters? I was thinking of buying a K&N CAI but the price is too much for me. Does dodge make a performance intake?
Old Mar 30, 2007 | 06:29 PM
  #258
Ganderguy's Avatar
Ganderguy
If you get the Mopar performance one it's $70 with a paper filter or you can get a k& N filter for an extra $40 Total cost me about $150 with the breather and all.
Old Mar 30, 2007 | 07:11 PM
  #259
Tarner's Avatar
Tarner
good thread!!!
Thanks for all the info.
Old Mar 30, 2007 | 08:09 PM
  #260
tinyfxds's Avatar
tinyfxds
Wow that's a lot cheaper than a K&N. I'll have to look into that
