oil pressure ?
Old Nov 12, 2006 | 04:44 AM
stovepipe's Avatar
stovepipe
Default oil pressure ?
my oil pressure guage shows lower at idle then when i get on the gas it goes high is this normal ? in my ford the pressure stayed the same all the time no matter what.
Old Nov 12, 2006 | 04:45 AM
dillonjm's Avatar
dillonjm
Default RE: oil pressure ?
Yes, it's normal.
Old Nov 12, 2006 | 06:06 AM
IndyRamMan's Avatar
IndyRamMan
yea i had the same question, its usuially right below 40psi when idleing/low speed crusin, but during acceleration its just slightly above or right at 40psi. didnt seem to fluctuate enough to me, but if thats how it is, cool.
Old Nov 12, 2006 | 06:52 AM
ryans590's Avatar
ryans590
yah your voltage will be lower at idle too. there all running off the moter so at higher rpm they spin faster (obvusally) so they get better preformance
Old Nov 12, 2006 | 08:32 PM
RM_Indy's Avatar
RM_Indy
Just posted this in another thread the minimum for a stock oil pump
6psi @ curb idle
30psi @ 3000rpms
If you are below that then there is a problem.
Old Nov 12, 2006 | 08:51 PM
shepard's Avatar
shepard
Regarding the Ford, I read somewhere that Ford (depending on how old) used a sensor that is on or off, not variable like most others. I think it comes on at 4psi, so you're right when you say it wouldn't move. My folks had a Ford van that made me wonder, oil pressure jumped to mid range on the gauge at startup and never moved, so I checked into it.
Old Nov 12, 2006 | 11:42 PM
stovepipe's Avatar
stovepipe
my voltage guage dont move. now there again it did move on my ford at idle with lights heat and wipers on. all lights would dimm . butt the dodge i can have everything on and it dont move and all the lights stay bright. i like this becuse the heat blower would slow down on my ford and the dodge is still blasting the heat blower on you at all times.
Old Nov 12, 2006 | 11:44 PM
stovepipe's Avatar
stovepipe
Old Nov 13, 2006 | 01:56 AM
dillonjm's Avatar
dillonjm
If your lights and stuff dim when you turn the heater and stuff on then your alternator is either too low of an amp for your accessories or isn't working properly.
