How much mileage do you have?
Old Nov 13, 2006 | 11:03 AM
Ram Man 98's Avatar
Ram Man 98
Default How much mileage do you have?
So every truck is different , but for everyones well being, what is your mileage, and what major / minor repairs have you had to do up to now? BONUS if you can remember what mileage the repairs were done at...
Here is mine, but since I have only had it a month- the past is shady.
1998 5.2 King Cab 4X4
96500 miles
replaced Daytime Running light Module ( It was already blown when I bought the truck)
The tranny need some adjusting ( hopefully that will fix everything)
I am sure other things were done, but I was not made aware
Old Nov 13, 2006 | 11:24 AM
Socha_62's Avatar
Socha_62
Default RE: How much mileage do you have?
96k Bought the truck-tune up
100k Right wheeling bearing
102k Cat clogged to the point it would hardly even idle
103k Left wheel bearing
112k Front axle seals and u joints
115k Fixed penum and t-chain for the hell of it, neither really had to be replaced
118k now
I can't complain for a truck having over 100k on it, I do all the work myself to so its a hell of alot cheaper.
Old Nov 13, 2006 | 12:36 PM
Ram Man 98's Avatar
Ram Man 98
Extra bonus if you remember the cost of parts/labour....
Old Nov 13, 2006 | 02:14 PM
nmason's Avatar
nmason
bought the truck 3.5 years ago. 89000km on it - plugs, cap, wires, rotor, headlights, wipers.
95000km - replaced crappy factory cat.
100000km - replaced all 4 shocks with sensatrac
115000 - new exhaust, flowmaster 40 series.
125000km - replaced starter
195000km replaced front springs with Moog, new front suspension linkage, new belt/tensioner, new water pump.
198000km - replaced drivers side rear hard brake line, horrible leak.
212000km NOW
Old Nov 13, 2006 | 02:16 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Purchase in the summer of 2005. I track everything on a spreadsheet.
Mileage Service
112,400 Upper/lower hoses, t-stat, serpentine belt, air filter, radiator flush
112,800 Pan gasket, trans gasket and filter; flush of trans, crankcase, and power steering
114,200 Cap, rotor, plugs, plug wires
114,500 Engine Rebuilt, New Fuel Pump, Exhaust System, Battery
You should see the spreadsheet for my Cavalier, which I have owned since Day 1
Old Nov 14, 2006 | 01:28 AM
ferbizkitstazi12's Avatar
ferbizkitstazi12
2001 2500
bought two years ago at 29,000 miles i now have 40,000 on it
29.5k dual 80 series flowmaster out b4 both tires 650$
29k put 8ft fisher plow which has never needed to be serviced in anyway 4k$
30k brake pads and rotors 400 in dollars in parts did work myself
i have 40,000 miles on it and thats all thats needed to be done so far and as far as the pads rotors go i plow so that really puts wear on them.......im also looking for new tires the stock ones are gettin pretty bad
Old Nov 14, 2006 | 02:10 AM
ddog737374's Avatar
ddog737374
80,000 upper and lower water hose
115,000 O-2 sensor
120,000 water pump
now running 130,000
Old Nov 14, 2006 | 02:13 AM
97Ram2500's Avatar
97Ram2500
purchased at 250,000 miles with a bad tranny. Working on replacement.
Going to need tires. Don't see much more wrong with it.
Old Nov 14, 2006 | 04:50 AM
94RAM1500's Avatar
94RAM1500
Only 36,700, 'cause I live my life 1/4 mile at a time...
My truck is in mint shape. I changed all of the fluids, the rear brake
line (driver's side), put an Auburn posi in, new thermostat, radiator
flush, all within the past 500 miles. Oh yeah, adjusted the tranny
bands too.
Old Nov 14, 2006 | 06:43 AM
habeba86's Avatar
habeba86
80,xxx
I have put new ball joints,u joint, thermo gasket....thats all I "had" to have done
