A/C Knob mod
Old Nov 16, 2006 | 05:39 AM
Mayfair's Avatar
Mayfair
Default RE: A/C **** mod
ORIGINAL: timwag2001
if you have any questions about what i just said... ask me when im sober.
LMAO !!!!!
Old Nov 16, 2006 | 04:57 PM
1RewdRam's Avatar
1RewdRam
......... actually I find if I drink it all makes sense ...............
Old Nov 17, 2006 | 08:37 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: mattyge
ya so how we make warm air blow on defrost?
If you can't get hot air to your windshield ducts, you've get a problem with your system. As I previously stated, mine gets hot enough to melt a pretty good coating of ice (not frost) on the OUTSIDE of the windshield ... even in 0 degree weather. It takes about 10 minutes of running at 2,000 RPM in the driveway ... but it works.
Old Nov 17, 2006 | 09:28 PM
timwag2001's Avatar
timwag2001
when you turn your heat on is it hot?
stupid question, when you turn your defrost on do you have the setting turned to hot or cold?
Old Nov 18, 2006 | 02:55 PM
blazelefty7's Avatar
blazelefty7
I also melt the ice off my windshield, did it last night when leaving the boat ramp when it was 25 degrees outside.. I usually let it run up to 5 minutes and that usually warms it up enough to wipe of with my blades. I have the same problem though with the compressor kicking on..and let me know if you guys find a way to fix..it annoys the crap outta me.
Old Nov 18, 2006 | 06:52 PM
jps's Avatar
jps
you can remove the AC compressor clutch relay
Old Jun 2, 2009 | 05:10 PM
Purcell's Avatar
Purcell
A/C needs to run to circulate the oil in the freon line, let it set all winter and you could have problems in the spring, summer. Same with the 4WD system with locking hubs, don't run the hubs locked for a year and then you have rust in the differential.
Old Jun 2, 2009 | 05:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
True about the AC , but you must have dug pretty deep to find a 3 year old thread! :0
Old Jun 2, 2009 | 06:57 PM
willstruck's Avatar
willstruck
My AC doesn't even work. Now that I live in california, and go out to the desert every weekend, I'm thinking I should get it fixed.
