hub bearing
Old Nov 15, 2006 | 11:25 PM
Darren's Avatar
Darren
Default hub bearing
Hey guys who knows if the right and left hub bearing on a 99 ram 1500 4x4 are the same parts. I want to swap my left and right to see if it eliminates a noise i am hearing thanks
Old Nov 15, 2006 | 11:59 PM
DieselDemon's Avatar
DieselDemon
Default RE: hub bearing
It may make a difference if you have 4 wheel antilock. My guess would be the sensor/magnet (whatever the setup is) might not be in timing if they swap sides?
Good luck.
Old Nov 16, 2006 | 12:08 AM
Darren's Avatar
Darren
I should of stated that my ram is non abs on the front, thanks
Old Nov 16, 2006 | 06:04 AM
kikidbird's Avatar
kikidbird
Yes it is the same part for the left or right. The only difference between the ABS is the magneto sensor. I have traveled from Los Angeles to Rapid City and my wheel hub bearing gave out twice. Now I cary a new set just in case.
