flashing mods
Old Nov 16, 2006 | 05:57 AM
kevo2k6's Avatar
kevo2k6
Default flashing mods
ok. i haven't really modded my motor because ive heard that you have to flash every mod or the computer will "learn it". but my question is what exactly is the pcm doing? because if you are increasing the the bore of a throttle body and porting manifolds, opening exhaust and such shouldn't you you still see gains? the motor is an air pump. i know its not a mass air system but my 90 camaro wasnt mass air either. it was computer controlled with the temp sensor in the intake. and when i opened up my intake and exhaust i added bigger injectors and i saw gains that didnt go away. can someone explain this in depth a little more to me?
Old Nov 16, 2006 | 12:00 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: flashing mods
i believe its something called speed density. I dont know about your camaro, but speed density is much more condusive for modding than a MAF system (IMHO). With speed density the computer has real time variables somewhat unlike the MAF system which is set to run with fixed variables but also uses real time variables. both systems assume a certian throttle body cfm and bore and whatnot, but with the maf system it meters the air velosity and uses the computer to compensate. (im not 100% familear with the speed density setup, but ill give you my general understanding of it) The air temp is mesured and computed with the ammount of throttle to get the ammount of air actually going into the intake. temp for the density of air. The TPS computes the throttle angle and throws the number into the equation. The computer is programed to know what cfm is flowing at each throttle angle. thats how the speed density is computed. now maf systems also have an air temp sensor too, but it does not play as big of a part as the tps and maf sensors. so when people say it learns the mods, it really doesnt, but yet does...confusing yea? say you put on a cold air intake. #1 your dropping the air temp, which the comp will pick up and add fuel for the denser air. #2 you will be getting increased airflow from the kit/filter, which the tps will not be able to compensate for. That means more air for an = ammount of fuel which= leaner mixture which = more power. your fine with running leaner, just dont run it too lean to the point where you get detonation. hope my confusing wording helped.
Old Nov 16, 2006 | 12:31 PM
Socha_62's Avatar
Socha_62
You don't have to reprogram the computer for every mod you do. The PCM will "learn" the diffrence after a while and will stop trying to correct it. It is a good idea to reset the PCM after every mod by unpluging the battery for 10 mins so the PCM "forgets" most of the stuff it knew from before.
You will see still noticable gains when you do mods, especially like intake manifold, heads, ect. You will get a bit more squeezed out of it if you do a custom program, which will also be noticable. But you WILL see a gain even if you don't reprogram the PCM.
Old Nov 16, 2006 | 12:37 PM
JD770's Avatar
JD770
ORIGINAL: IndyRamMan
Out of the box, speed density out performs a MAF system, but unlike a SD system an MAf system can be modded further without "custom" tuning.
I went through this with my 306 mustang and eventually converted it to MAF to smooth out idle and tune problems
Old Nov 16, 2006 | 12:41 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: JD770
ill haveta agree with you on that. Tho having a speed density on an obd2 system has got to be easier to work with. i dont know first hand...yet, but everything seems to be there for ease of opperation and tuning.
Old Nov 16, 2006 | 12:51 PM
Silver_Dodge's Avatar
Silver_Dodge
Magnum motors are speed density motors as stated above, but speed density designs are actually less condusive to mods then mass air flow (MAF) designs. Unlike MAF designs, speed density engines have no way to accurately measure the amount of incoming air into the cylinders. Speed density engines have to use a combination of readings from different sensors (MAP, TPS, etc) to give the PCM some idea of how much air is present. It then takes these estimates, and makes adjustments as needed to keep other sensor outputs within spec (O2's). The amount it can adjust is restricted though in that during openloop modes, the PCM is limited to using pre-programmed settings only. This means that no matter how much air you put in, the PCM can only adjust so much before it reaches the maximum values it has preprogrammed. Increasing air ratios beyond that will result in lean conditions. The increases that you do see from increasing air come from: 1) freeing horsepower that has been lost due to "detuning" to meet certain DOT/Federal emissions criteria, and 2) increases seen as the PCM moves into the outer limits of it's pre-programed settings.
So, you can increase the air flow through things like TB mods, CAI, and intake mods. The PCM will use that increased air to the best of its abilities, but you will reach a point where the PCM just can compensate any further for that amount of air. That is the point when you will want a flash to tell the PCM how to use that extra amount of air if it determines through the sensor inputs that it is available.
Old Nov 16, 2006 | 09:41 PM
kevo2k6's Avatar
kevo2k6
so what about putting bigger injectors to compensate for more air?
Old Nov 16, 2006 | 09:49 PM
Silver_Dodge
PCM won't know what to do with them. Definetly need a flash to handle bigger injectors.
