ABS/Brake Warning
Old Nov 17, 2006 | 02:23 PM
dodgeram sport99's Avatar
dodgeram sport99
Default ABS/Brake Warning
My ABS and Brake Warning Dash lights just came on simultaneously and haven't gone off since. What do I need to inspect to see what's happening with the ABS myself?
thanks for any recommendations
Dodgeram sport99
Old Nov 17, 2006 | 03:46 PM
Racinfan83's Avatar
Racinfan83
Default RE: ABS/Brake Warning
It's not the ABS system. 90% chance your speed sensor on the rearend is bad. Dealer-only part - about $45. Change it yourself. Reset the computer. http://www.v8performance.com/tipsandtricks.htm#ResetPCM Done deal.
Old Nov 17, 2006 | 04:39 PM
1980blackfiveoh's Avatar
1980blackfiveoh
I'm sure it is the speed sensor is the rear diif. This seems like such a common problem (this and the throttle position sensor seem to go in all these trucke)
Old Nov 17, 2006 | 05:44 PM
jisthangin01's Avatar
jisthangin01
Thats funny because mine also came on about a half hour ago. The Brake light and ABS light came on, than when i restarted the truck, my speedometer stopped reading.
Old Nov 17, 2006 | 06:45 PM
nmason's Avatar
nmason
mine did that a few weeks ago. both on, no apparent reason. then 2 days later the brake line leak got bad enough for me to notice it. check for leaks too
Old Nov 17, 2006 | 07:50 PM
mopar98's Avatar
mopar98
Yeah it's the rear wheel speed sensor I changed min e3 months ago . It did the same thing abs & brake light came on and then my speedometer quit working.
It is a dealer item only like Racinfan83 said the new one for mine came with a extension wire plug because they changed the design.
Old Nov 18, 2006 | 06:16 AM
jisthangin01
Pain in the *** to put in?
Old Nov 29, 2006 | 11:13 AM
dodgeram sport99
Thanks for the info. and the print-out tips, You rock...
Dodgeram sport99
Old Nov 29, 2006 | 12:05 PM
Socha_62's Avatar
Socha_62
ORIGINAL: Racinfan83
agreed
