Plenum Gasket
Old Nov 26, 2006 | 10:30 PM
yingchu777's Avatar
yingchu777
Default Plenum Gasket
Can someone help me locate the plenum gasket and explain how to check it for leaks related to the Death Flash. Although there is no pinging or loss of power in the truck I am worried about the flash and think checking the plenum gasket should be done. Thanks.
Old Nov 26, 2006 | 11:08 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Plenum Gasket
Try searching for "plenum" and you'll find enough information to make an educated decision.
Old Nov 26, 2006 | 11:12 PM
timwag2001's Avatar
timwag2001
the plenum is the pan that is bolted onto the underside of your intake manifold. the gasket is inbetween the plenum pan and the manifold. if you take your throttle body off and look straight down, what you would be looking at is the plenum pan. if you look in the corners and see oil pools you have a leak.
look at your computer and check to see if you have a sticker that says something like "authorized software upgrade".
if you do a search on it you should have enough knowledge on it to do a repair with a blindfold and have one arm and two legs tied behind your back with a ball gag in your mouth.
Old Nov 27, 2006 | 12:42 AM
yingchu777's Avatar
yingchu777
Where can I find what the computer looks like because the only box I see is under the stearing wheel tucked near the firewall and there is no sticker like you described. There is a square sticker with no bar codes and a paragraph describing compliance with codes. The only other labeling is attached to the back of the outside of the glovebox and it is hard to read but has the word supplier on it, some numbers and two bar codes. What determines whether or not a Death Flash sticker is applied? Thanks for the help.
Old Nov 27, 2006 | 12:48 AM
yingchu777's Avatar
yingchu777
VWandDodge, thanks for the plenum tip.
Old Nov 27, 2006 | 02:57 PM
steve05ram360's Avatar
steve05ram360
here is a writeup on it... its an easy fix, https://dodgeforum.com/m_249261/tm.htm
I think there is a link to a TSB that has another way of checking for a leak. the visual is the best way however.
Old Nov 27, 2006 | 11:17 PM
kikidbird's Avatar
kikidbird
I have my manifold off because im OH my engine. Should I replace my plenum with an aftermarket one? Or is the stock ok with a new gasket?
Old Nov 28, 2006 | 01:17 AM
steve05ram360
do the aluminum plate & felpro gasket... use new plenum plate bolts (should come with the plenum kit)
Old Nov 28, 2006 | 10:06 PM
TMS Bill's Avatar
TMS Bill
yingchu777: The computer being spoken of is under the hood on the firewall (passenger side). It's a little bigger than a TV Guide and has 3 large harnesses going into it's face.
Old Nov 28, 2006 | 10:28 PM
yingchu777's Avatar
yingchu777
TMS Bill, thank you , I was able to locate it to find no Death Flash on it.
You have a great looking Ram!
