Gutting Cat
Old Nov 28, 2006 | 09:24 PM
Works4Ford's Avatar
Works4Ford
Default Gutting Cat
I've got a 2001 Ram 1500 5.2L...it's getting 10.6 mpg right now. How would one gut the catalytic converter?
Old Nov 28, 2006 | 09:54 PM
jisthangin01's Avatar
jisthangin01
Default RE: Gutting Cat
Are ya sure your cats clogged? My mpg dropped down in the past month alot, apparently because of oxygenated gas or somthing. I just went on a trip and averaged 11.8 on the highway with some stop and go traffic. And around town i think i just did it a few days ago, and it was somthing like 10.5. ****ty if ya ask me. Oh well. Anyways, if you wanna gut your cat, i'd say the easiest way on these trucks would be to cut open the bottom of the cat - Cut somthing like a square, but only cut 3 sides of it and bent the tab you made down, break apart the inside, push it back up and weld it together again. Thats only helpful if you own or have access to a welder or course. I ended up just replacing mine with a new one. It was easier. The only part that sucked was trying to get the bolts out of the passenger side of the truck. Well good luck!
Old Nov 28, 2006 | 09:59 PM
TPSDODGE's Avatar
TPSDODGE
you guys should stop gutting your cats.. just put a pipe in there and sell those cats, there worth about 40 bucks used.
Old Nov 28, 2006 | 11:25 PM
JarheadX's Avatar
JarheadX
I heard you can't sell cats, maybe it is diff in NYS...but i gutted mine, welded it up and now no1 can even tell, i got a performance increase, and ssounds like its gunna kill sum1
Old Nov 29, 2006 | 12:04 AM
mopar98's Avatar
mopar98
You can sell cats here in ohio . They're worth a lot because of the material they're made of.
My brother worked at a junk yard for one summer and they made a butt load off recycling old cats .
So I would say put in some pipe and save yourself some time and maybe get a little money out of the deal.
Old Nov 29, 2006 | 01:08 AM
jm22876's Avatar
jm22876
Theres platinum in cats...thats why their worth $$$$ In these devices platinum, palladium and rhodium catalyse reactions that convert hydrocarbons, carbon monoxide, and nitrogen oxides into less noxious emissions.
Old Nov 29, 2006 | 03:07 AM
jisthangin01
Learn somthin new every day
Old Nov 29, 2006 | 03:10 AM
1996ramkid's Avatar
1996ramkid
cut off one of the input pipes and stick a pice of pipe down there and chop it up till it falls out the back half
