OD Solenoid / TCC Problem
Old Nov 29, 2006 | 04:01 PM
Alex18444's Avatar
Alex18444
Default OD Solenoid / TCC Problem
I have 2001 Dodge Ram 1500 with 5.9L
Only got 56000miles
Check engine light came on - the code was OD Solenoid / TCC
Took the truck to a transmission place, they replaced the solenoid switches.
One month later, Check engine light came back on with the same code.
Any suggestion?
Old Nov 29, 2006 | 08:20 PM
scbcman's Avatar
scbcman
Default RE: OD Solenoid / TCC Problem
I recently had the same problem, though I was throwing a P0740 Code. The tranny mech. changed out the solenoids but that was the least of my problems. I just didn't know it. My TC was just beginning to wear as well. Even with the new solenoids, (which did need replaced) enough metal got into the new switches to short them and throw lights as well ( not to mention the TC itself being shot.) Also lost my OD planetary gears. That was a few weeks ago. I should be good for another 36000 miles with my completely rebuilt tranny!
Old Nov 29, 2006 | 08:38 PM
DieselDemon's Avatar
DieselDemon
I would check your grounds. What gave you an indication there was problem to begin with, just the CEL? What about the actual tc lockup and such?
Good luck.
Old Nov 30, 2006 | 05:32 PM
Alex18444's Avatar
Alex18444
Just the CEL came on. Truck is running fine. The transmission place said nothing looks wrong with it. Replaced the switches the 2nd time for free.
Can it be just a bogus code?
Old Nov 30, 2006 | 08:23 PM
DieselDemon
I doubt it. Again, I would make sure the ground connections are good. Dodge has sh!tty grounds that get worse with time.
Good luck.
Old Dec 1, 2006 | 03:06 PM
Alex18444's Avatar
Alex18444
Thanks. I'll look in to that.
Old Dec 1, 2006 | 03:24 PM
2001ramsport's Avatar
2001ramsport
have them do a stall test on your TC.had to replace mine @80,000 mi
