Upgrade 01 stereo to 05 - will it fit?
Old Nov 29, 2006 | 04:43 PM
loot87's Avatar
loot87
Default Upgrade 01 stereo to 05 - will it fit?
I'm thinking of upgrading my standard RAZ AM/FM/CD stereo in my 01 2500 to an 05/06 model with aux-in and mp3 capability.
Will these fit in the hole? I'll just keep using the stock speakers and wiring.
Is the only big deal making a wiring harness adapter?
Does anyone make a harness to bridge the two connectors from the 01 to the single 22 pin connector used by the 05?
The factory manual also says that the RAZ steroes communicate on the CCD (Chrysler Collision Detection) bus. What's that about and do I need to worry about that on an 05 stereo?
Thanks.
Chris
Old Nov 29, 2006 | 06:13 PM
Zeppelinrocks's Avatar
Zeppelinrocks
Default RE: Upgrade 01 stereo to 05 - will it fit?
i say go aftermarket, they are better quality and sound better
Old Nov 29, 2006 | 06:43 PM
loot87's Avatar
loot87
Can you recommend one that looks good? It's a shame to put a tiny stereo in such a huge hole.
Old Nov 29, 2006 | 06:51 PM
Zeppelinrocks
its all personal taste and how much you want to spend. They have some that have lite shows and all that and they also have basic ones that just display the basics. or if you want to you can get an in dash gps/dvd player, i believe those run close to 1000 dollars though. as far as the size they have dash kits that dont look too bad.
Old Nov 29, 2006 | 07:52 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: loot87
thats the metiphore your girlfriend used isnt it
Old Nov 29, 2006 | 09:19 PM
nmason's Avatar
nmason
my aftermarket kenwood looks alright in the space i have, it sticks out a few mm further than i would like, but yeah, the kits they sell work pretty well. if you have a double sized spot you can find aftermarket decks made to fit, but i dont think thatll work for you
Old Nov 30, 2006 | 04:14 AM
loot87's Avatar
loot87
ORIGINAL: IndyRamMan
ORIGINAL: loot87
I think this is where I'm supposed to say something about your mom....
Old Nov 30, 2006 | 10:40 AM
jm22876's Avatar
jm22876
If you look into the Pioneer line of products...they have a double din size head unit, about the same size as factory. single din being standard aftermarket size head units. Hope it helps
