Torque Converter
Old Nov 29, 2006 | 10:12 PM
Strawboss10's Avatar
Strawboss10
Default Torque Converter
2000 Ram TC keeps shifting in and out at most speeds over 30 mph. Check engine light does NOT come on. I took it to a dealer and he told me no big deal don't worry about it, but it is getting worse the more I drive it.
Any suggestions?
Thanks
Old Nov 29, 2006 | 11:05 PM
DieselDemon's Avatar
DieselDemon
Default RE: Torque Converter
Check your brake light switch. If the brake light switch is bad or misadjusted, you will have trouble keeping the cruise control engaged as well as an erratic tc locking and unlocking.
Good luck.
Old Dec 1, 2006 | 05:04 PM
Strawboss10
Thanks for the reply. The cruise control seems to be working fine but the TC still shifts in and out. It is almost like a skip in the engine. Could a very slight skip cause the TC to engage in and out?
Old Dec 1, 2006 | 05:26 PM
timwag2001's Avatar
timwag2001
could it be a bad tps?
Old Dec 1, 2006 | 05:35 PM
Strawboss10
Thanks for the reply but what is a tps?
Old Dec 1, 2006 | 05:44 PM
timwag2001's Avatar
timwag2001
throtlle postion sensor. its on the drivers side of the throttle body
when the tps goes bad it gets "noisy". the signal a noisy tps sends back to the pcm tells it that the throttle is open farther than it really is and the pcm unlocks the torque converter. it makes the TC lock and un-lock
i pulled this info from another thread.
the idle air control motor (iac) is on the back of the throttle body. could be causing some problems for you also. take it out and clean it with some throttle body cleaner.
Old Dec 1, 2006 | 05:51 PM
Strawboss10
Thank you. I will try that.
Old Dec 2, 2006 | 03:40 PM
Strawboss10
I cleaned the throttle body and the tps this morning. That seemes to have fixed my proplem. No more locking and unlocking of the tc. Thanks so much for the great help Tim!!
Old Dec 2, 2006 | 04:17 PM
jnellydodge's Avatar
jnellydodge
ORIGINAL: Strawboss10
Glad that it seemed to fix the problem! For peace of mind my truck was doing the exact same thing you described and it turned out to be the TPS was bad.
Old Dec 2, 2006 | 04:25 PM
Socha_62's Avatar
Socha_62
Cleaning the TPS fixed it? usually the only way to fix a TPS is to buy anew one.
