ABS sensor did not fix it
Old Dec 2, 2006 | 05:57 PM
IndyRamMan's Avatar
IndyRamMan
Default ABS sensor did not fix it
My ABS and Brake lights are on on my dash. I was told that it was probabily the abs sensor in my diff. I just changed that out, and the lights did not go away. Whats next?
Old Dec 2, 2006 | 08:45 PM
Racinfan83's Avatar
Racinfan83
Default RE: ABS sensor did not fix it
I assume you mean you changed the speed sensor in the rear end, right? Did you reset the computer after you did it? If you reset the computer and it still comes on, there might be another issue with it that I don't know about.....
Old Dec 2, 2006 | 09:07 PM
timwag2001's Avatar
timwag2001
the computer does not automaticly reset codes. unplug battery like racinfan said
Old Dec 3, 2006 | 01:55 PM
IndyRamMan's Avatar
IndyRamMan
ok.
Old Dec 3, 2006 | 02:58 PM
timwag2001's Avatar
timwag2001
how did it go?
Old Dec 3, 2006 | 03:23 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: timwag2001
how did it go?
my terminals are like enfused to the posts...im gonna have to get new terminals before I attempt to take them off. Looks like someone got hungry and started gnawing at them.
Old Dec 3, 2006 | 03:27 PM
Racinfan83's Avatar
Racinfan83
Thats what happens when someone uses vice grips or pliers to do what you need a wrench for. [:@] Good Luck. Get some "battery terminal protection spray" while you are at the parts store and spray that on the terminals when you get done to keep off the corrosion.
Old Dec 3, 2006 | 05:49 PM
timwag2001's Avatar
timwag2001
i had picked up some plated terminals from autozone. not really of the greatest quality but all of the wires attatch to the terminal via allen key. so you dont have to take your terminal off to disconnect battery, just unscrew the allen screws. it also has a couple exra holes for auxillary electronics.
Patriots are winning after the half [sm=alcoholic.gif]
Old Dec 4, 2006 | 09:08 PM
TMS Bill's Avatar
TMS Bill
Sorry guys ... IIRC the ABS/brake light thing doesn't come from the PCM. It comes from the ABS controller. There are no codes to reset.
Check the fuse ...
