Running without a CAT??
Old Dec 3, 2006 | 07:16 PM
01DodgeRam 1500's Avatar
01DodgeRam 1500
Default Running without a CAT??
Any PROS?? or CONNS? for running my 01 1500 5.9L 4X4 without a CAT?
Old Dec 3, 2006 | 07:22 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
Default RE: Running without a CAT??
cons
your not gonna pass inspection
possibly could throw a code
pros
better sound
better power
Old Dec 3, 2006 | 07:39 PM
01DodgeRam 1500
This state doesn't have inspection. Will I increase HP or Torque?
Does anyone know what code if any would be displayed?
Thansk
Old Dec 3, 2006 | 08:12 PM
dflyboy's Avatar
dflyboy
it woud be the code for the rear O2 sensor (the one behind where the cat is saposed to be). Dependig on the exhaust that you have without the cat you will loose back pressure... if you have dual or large exhaust you may not have enough back pressure and will loose some low end tourqe. I am running without a cat, and i have a 2.5" single exhaust. i dont notice any difference, except it sounds way meaner. I also put in a O2 simulator so i didnt have my CE light on all the time.
Old Dec 3, 2006 | 08:14 PM
01DodgeRam 1500
Were did u get the O2 simulator?
Old Dec 3, 2006 | 08:26 PM
dflyboy's Avatar
dflyboy
I got it from O2simulator.com. It was the most informative web page and a easy install because it tells you the colors of the wires in your truck.
Old Dec 4, 2006 | 12:35 AM
Sinister's Avatar
Sinister
i have no CAT. and previous to the 2nd half of 99, the sensors weren't throwing codes, 1999 2nd and newer, without a cat, it will throw a code.
i recently had a "short to o2 sensor" code, I cleared it, and hasn't since put out a CE light again.
