Exhaust "Y" pipe
Old Dec 3, 2006 | 10:55 PM
Dodge4x4magnum's Avatar
Dodge4x4magnum
Default Exhaust "Y" pipe
Hey guys, i was wondering if anyone had a y pipe off of a 94 - 01 Dodge ram 1500. im trying to make a true dual exhaust and i need to get one but they are like 400 dollars new because they got the cat with them. Thanks alot.
Old Dec 3, 2006 | 11:00 PM
Ram1500Dodge's Avatar
Ram1500Dodge
Default RE: Exhaust "Y" pipe
how do you figure true dual with a Y pipe? am i not understanding correctly?
Old Dec 3, 2006 | 11:06 PM
01DodgeRam 1500's Avatar
01DodgeRam 1500
I think he wants an "H" pipe.
Old Dec 3, 2006 | 11:20 PM
ripto's Avatar
ripto
yea my friend was thinking about true dual and he said you need some pipe to cross them over or something, like an x-pipe, is this true?
Old Dec 4, 2006 | 12:43 AM
Ram1500Dodge
ORIGINAL: ripto
X or H, or neither, just go str8 back and dont worry about crossing or connecting them
Old Dec 4, 2006 | 12:55 AM
20dodgeram01's Avatar
20dodgeram01
you dont connect true dual at all.. from each header you run it straight back. meaning 2 cats.. 2 mufflers. like "ll".. "H" is running both headers into 1 muffler (usually 2 cats though) and dual exhaust out.. "Y" is running both headers into a single cat and muffler
Old Dec 4, 2006 | 01:27 AM
Ram1500Dodge
ORIGINAL: 20dodgeram01
h pipe is 2 cats(if desired/required) and 2 mufflers(if required/desired) boss. why would you have 2 cats and 1 muffler? H pipe just has a connecting pipe to balance out pressure.
Old Dec 4, 2006 | 01:49 AM
20dodgeram01
kinda figured where the pipes come together is where it comes into the muffler.. then splits back out to dual exhaust.. 2 cats.. then the pipe comes together
Old Dec 4, 2006 | 02:25 AM
ripto's Avatar
ripto
ORIGINAL: Ram1500Dodge
so the H pipe is required or no?
Old Dec 4, 2006 | 03:40 AM
nim81's Avatar
nim81
you need an H pipe to connect the exhause together, otherwise its like running two 4 cylinder engines in your truck instead of one 8 cylinder. the H pipe or x pipe makes both sides of your engine run right instead if fighting eachother.
