Anti-Spin Rear Diff?
Old Dec 6, 2006 | 12:36 AM
Ryanshreds's Avatar
Ryanshreds
Default Anti-Spin Rear Diff?
On my truck I have the anti-spin rear diff. What is this? Is it like limited slip? And does it work in more than just four low?
Thank You
Old Dec 6, 2006 | 01:21 AM
Parts/Service's Avatar
Parts/Service
Default RE: Anti-Spin Rear Diff?
TRAC-LOK OPERATION
In a conventional differential, if one wheel spins, the opposite wheel will generate only as much torque as the spinning wheel.
In the Trac-lok differential, part of the ring gear torque is transmitted through clutch packs which contain multiple discs. The clutches will have radial grooves on the plates, and concentric grooves on the discs or bonded fiber material that is smooth in appearance.
In operation, the Trac-lok clutches are engaged by two concurrent forces. The first being the preload force exerted through Belleville spring washers within the clutch packs. The second is the separating forces generated by the side gears as torque is applied through the ring gear Trac-lok Limited Slip Differential Operation
The Trac-lok design provides the differential action needed for turning corners and for driving straight ahead during periods of unequal traction. When one wheel looses traction, the clutch packs transfer additional torque to the wheel having the most traction. Trac-lok differentials resist wheel spin on bumpy roads and provide more pulling power when one wheel looses traction. Pulling power is provided continuously until both wheels loose traction. If both wheels slip due to unequal traction, Trac-lok operation is normal. In extreme cases of differences of traction, the wheel with the least traction may spin.
[IMG]local://upfiles/2784/9074A88471DE48EE9DC9D64757B9255A.gif[/IMG]
Old Dec 6, 2006 | 01:42 AM
TMS Bill's Avatar
TMS Bill
What he said ^^^^^.
... Trac-loc is Dodge's name for thier limited slip diff ... and it works all the time, not just in 4-lo.
Old Dec 6, 2006 | 11:31 AM
Ram Man 98's Avatar
Ram Man 98
Do all Rams have this feature?
Old Dec 6, 2006 | 06:16 PM
mattyge's Avatar
mattyge
unfourtantely no, it was an option and my truck doesnt have it and it gets stuck easily cause only the back left wheel will spin, and in a burn out only leave one tire mark[:'(]
Old Dec 6, 2006 | 07:12 PM
spiral72's Avatar
spiral72
Auburn Gear makes (made?) it for Dodge.
Old Dec 6, 2006 | 08:26 PM
Socha_62's Avatar
Socha_62
ORIGINAL: TMS Bill
Hahaha, more like it work when you don't need it to
It is suppose to work all the time lol
Old Dec 6, 2006 | 08:34 PM
TMS Bill's Avatar
TMS Bill
I stand corrected ... [&o]
Old Dec 7, 2006 | 12:36 AM
GOD RAM IT's Avatar
GOD RAM IT
factory trash loks are garbage.
