thermostat question again
Old Dec 11, 2006 | 08:07 PM
wildwolf59's Avatar
wildwolf59
Default thermostat question again
hey guys i want to ask the thermostat question again...i am not looking for more power or anything all i want to know is the 180 going to be better for my truck than the 195??? and should i go ahead and drill the tiny hole in it if it doesnt have it??? or is this question just going to be one of those where the answer is going to be half and half all the time....not trying to be a smart*** here or anything i just want what is going to be best for the truck running wise!!!! thanx for any help in advance!!!!!
Old Dec 11, 2006 | 08:31 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: thermostat question again
You do not need to drill a hole in your thermostat, and I will argue that with ANYONE on this board. It is a complete and utter crock. Park the truck on service ramps if you cannot park it on an incline. Top off the radiator and then run it until the engine reaches the desired temperature (with the radiator cap off from the start). Keep an eye on the coolant level as it drops, topping it off on occasion. Be prepared for when the air starts to work it's way out of the system as the radiator will "burp", with some bits of coolant, but mostly a rush of air coming out of the radiator. Total time spent will be approximately 20 minutes topping off the system.
I also recommend against the 180º t-stat as well, but other will come in claiming it causes the engine to create more power.
Old Dec 11, 2006 | 08:44 PM
timwag2001's Avatar
timwag2001
i was throwing codes with the 180.
Old Dec 11, 2006 | 08:45 PM
Silver_Dodge's Avatar
Silver_Dodge
I would not argue that a 180 "creates" more power. What it does is allow the engine to run a little cooler so that other mods that do create more power will be less likely to result in pinging. By itself though, it will not create any noticable power. Those who say it does are just hoping so hard that they will see gains from everything they bolt on that they trick themselves into thinking a simple t-stat change made a notiocable performance difference.
Old Dec 11, 2006 | 10:53 PM
wildwolf59's Avatar
wildwolf59
like i said i dont want to do it for the mod i just want to know if it will help the motor last longer in the long run by cooling it better or will it do more damage like the codes....right now i think it it stuck open so i am going to change it but i dont know which one to put in it....whichever i wont drill the hole cause i have the ramps and i can burp it that way but still dont know if it will be the 180 or 195....i think i will just put 195 in it because that is what is in it already unless i can be convinced that i should put in the 180!!!!like i said i am not going to do it for the "more power" deal!!!
