Your vote on a sub (10")
RE: Your vote on a sub (10")
TC Sounds pwns all!!!!
http://www.tcsounds.com/db500.htm
Fi is the new internet brand of the past couple months....but for good reason.
https://ssl.perfora.net/www.ficaraud...iew.shopscript
The tc needs about an inch more mounting depth than the fi, but if you can get it in the box you were looking at I would go with the TC for sure.
To install this you will need the following
sub
amp
power/ground wire
rca's
remote wire for amp
speaker wire
fuse holder/fuse
box
This is assuming you have an aftermarket headunit...if not the rca's wouldnt be needed and you would need something else, but we will deal with that if you don have an aftermarket. How much were you wanting to spend on everything, that will help with what is reccomended.?
sub
amp
power/ground wire
rca's
remote wire for amp
speaker wire
fuse holder/fuse
box
ORIGINAL: habeba86
sub
amp
power/ground wire
rca's
remote wire for amp
speaker wire
fuse holder/fuse
box
sub
amp
power/ground wire
rca's
remote wire for amp
speaker wire
fuse holder/fuse
box
I dont have an aftermarket headunit, nor do i want one. I like the factory look. It is the Infinity system though, so I dont know if that came with a higher amp headunit or not.
I really dont want to spend more than like 350-400.
i personally like MTX Thunder 4500 subs, about 120-140 a piece for 10's and they kick plenty hard, especially for the small cab of a truck. mine's in a really narrow box, about 6 in deep. not alot of boom outside but inside it's great. i don't know what model my amp is off the top of my head, but it's a tiny kicker amp. i have the bass setting on lowest possible on the amp and it thumps great. i like something this size for the cab of a truck, hardly noticeable.
PS, did anyone know that silicone works great for patching holes in your speakers?
