cam pos. sensor. !!! prob solved, burning oil now
Old Dec 14, 2006 | 06:09 PM
nim81's Avatar
nim81
Default cam pos. sensor. !!! prob solved, burning oil now
camshaft position sensor codes came up on my truck . 5.9.
do i replace my crankshaft position sensor? as of now my truck wont start and this is the only code on the computer. any help would be awsome thanks!!!
thanks guys it was the crank position sensor. truck runs great now, but burns oil real bad, smokes more and more the higher the rpms are. any ideas on that?? it blows smoke like my boss on a bad day at work.
Old Dec 14, 2006 | 06:15 PM
RM_Indy's Avatar
RM_Indy
Default RE: need fast help please!, camshaft pos. sensor. !!!
Camshaft position sensor is the black plastic ring inside the distributor. Tells the pcm where the cam is so it fires the injectors at the right time.
Old Dec 14, 2006 | 06:43 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Check for a broken wire, first. Otherwise, it's like Indy stated. I think it's a dirt cheap part anyway. Just a semi-ring of metal on a plastic circle.
Old Dec 15, 2006 | 01:40 AM
timwag2001's Avatar
timwag2001
Default RE: need help camshaft pos. sensor. !!! prob solved, burning oil now
ORIGINAL: nim81
is the smoke coming from the engine or exhaust?
Old Dec 15, 2006 | 03:04 AM
nim81's Avatar
nim81
smokin from exhaust,
im hoping it will go away by itself?
Old Dec 15, 2006 | 12:31 PM
nim81's Avatar
nim81
any ideas anyone? im hoping the rings arent bad. the truck had just over 198xxx miles on it. never smoked before the cps went out. still runs good but now its smokey, definatly oil from exhaust the higher the rpms are. maybe some aftermarket oil additive will help? just had the oil changed like month ago. if that.
Old Dec 15, 2006 | 12:59 PM
Dodge4x4810's Avatar
Dodge4x4810
Default RE: cam pos. sensor. !!! prob solved, burning oil now
Have you checked your plenum gasket?
Old Dec 15, 2006 | 01:09 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: nim81
198K miles and you're hoping the rings aren't going bad??? Damn, you got your monies worth out of that. Sounds like rebuild time to me.
Old Dec 15, 2006 | 02:43 PM
dflyboy's Avatar
dflyboy
look down in your intake with a flashlight, if you can see oil pools or its real dirty then change your plenum gasket and that should solve your problem.
Old Dec 15, 2006 | 03:34 PM
RM_Indy's Avatar
RM_Indy
ORIGINAL: nim81
I can think of a few numerical fixes. They are 402, 408 or 426
Its rebuild time
