Front inner tire rubbing
Old Dec 22, 2006 | 03:11 AM
jmrodriguez20's Avatar
jmrodriguez20
Default Front inner tire rubbing
the problem i am having is the front tires are rubbing against the lower control arms at full turns.How do i adjust the tireturning radius or how do i correct this problem?
265/75 R16
2000 dodge ram 1500
5.9 non 4X4
Old Dec 22, 2006 | 03:22 AM
Scottr1110's Avatar
Scottr1110
Default RE: Front inner tire rubbing
i dont know how to adjust it but i mean my dad bought mine brand new and its always done it on a full lock dont think its that big of a deal to be honest i do remember there are little adjusters on the control arms to stop it from turning think thats how u correct this problem
Old Dec 22, 2006 | 03:24 AM
Sinister's Avatar
Sinister
there are stop bolts on the inside of the steering knuckle on both wheels, adjust those outwards in order to prevent rubbing, however you will lose turning radius.
Rule of thumb: Right bolt affects Left Wheel, and Vice Versa.
Old Dec 22, 2006 | 03:37 AM
jmrodriguez20
does the tire have to be off in order to adjust the stop bolts on the steering knuckle?
Old Dec 22, 2006 | 04:06 AM
Scottr1110's Avatar
Scottr1110
no its basicly just a bolt on the knuckle just look i forget if its on the front or back of the knuckle just turn it till it dosnt rub anymore
Old Dec 22, 2006 | 05:17 AM
jmrodriguez20
my knuckles do not have a stop bolt on them nor does it have holes where one should be, would there be another place to look?
Old Dec 22, 2006 | 09:30 AM
kstroeher's Avatar
kstroeher
My '01doesn't have them either, I've been thinking of drilling and tapping a set in.
Old Dec 22, 2006 | 09:03 PM
Sinister's Avatar
Sinister
as far as I know that is the only spot they are supposed to be,.
I'll find my old thread, and repost the image here.
edit*
here you are
Old Dec 22, 2006 | 09:53 PM
k12allen's Avatar
k12allen
My 96 has the stops on the steering knuckles and I bet all Ram's do - at least Gen 2 1500's. It's on the front of the knuckle pretty near the bottom. Size is something like 3/8ths. The hexhead is the stop. There'sa nut on the bolt you tighten agaist the knuckle to keep it adjusted.
My tires rub on the lower control arms too, but my stop bolt is so rusty it might break if I try to adjust.
Allen
Old Dec 22, 2006 | 10:53 PM
kstroeher's Avatar
kstroeher
My '01 1500 does NOT have them.
