How do you know if you have an LSD rear end?
Old Dec 23, 2006 | 05:12 PM
jktrepin's Avatar
jktrepin
Default How do you know if you have an LSD rear end?
How do you know if you have an LSD rear end???
Thanks,
Jake
Old Dec 23, 2006 | 05:23 PM
Ryanshreds's Avatar
Ryanshreds
Default RE: How do you know if you have an LSD rear end?
Open your hood. On the underside of it right by the grill there will be some info on the options you truck has, including gears and diff options.
Old Dec 23, 2006 | 05:32 PM
Mike Roma's Avatar
Mike Roma
Or, do a burnout, and count the stripes![sm=gears.gif]
Old Dec 23, 2006 | 07:39 PM
jktrepin's Avatar
jktrepin
lol my truck sucks at burning out, so i bet its not an LSD but i'll check, thanks!
Old Dec 23, 2006 | 09:26 PM
indianaman's Avatar
indianaman
i want to know this also. i found the numbers XCRXT05.95B1 and XCRXEO174GDH what do these mean?
Old Dec 23, 2006 | 09:41 PM
radwebster's Avatar
radwebster
assuming your LSD is in good working condition...
you can jack the back of the truck up and try to turn one wheel. one tire will turn the opposite direction of the one you're turning if you have an open differential. they will both turn the same way if its an LSD.
Old Dec 23, 2006 | 10:41 PM
IndyRamMan's Avatar
IndyRamMan
If you do have an lsd and dont want one, you can always give it to me.
Old Dec 23, 2006 | 11:08 PM
Ram_Sport's Avatar
Ram_Sport
or me...
Old Dec 24, 2006 | 04:23 PM
jktrepin's Avatar
jktrepin
alright i did a burn out and i only had one solid black line..... lol but does anyone know what those letters and #'s mean on the inside of your hood?..... like what indianaman said.... I want a posi-differential... i want both wheels to spin when i burn out. What is so great about LSD rearends?
Old Dec 24, 2006 | 04:30 PM
radwebster's Avatar
radwebster
ORIGINAL: jktrepin
posi and LSD are the same thing. posi is GM's name for a limited slip differential. for the ram its a trac-loc or somethin. they're all the same function.
you most likely have an open differential (or a wrecked LSD).
limited slip helps alot in offroading situations where one tire might sit and spin and leave you stuck.
