HELP NEEDED ROTAR STUCK!
Old Dec 27, 2006 | 02:32 PM
mattyge's Avatar
mattyge
Default HELP NEEDED ROTAR STUCK!
Hey guys halfway through my replacement of cap rotar plugs and wires and i can't seem to get the rotar off. ANy suggestions it is also in the most inconvient place
Old Dec 27, 2006 | 04:37 PM
indianaman's Avatar
indianaman
Default RE: HELP NEEDED ROTAR STUCK!
mine was the same on my 99. i took an open ended wrech and fit it around the rotor and used a block of wood to lever it off. be carful though, not to bend the shaft
Old Dec 27, 2006 | 04:49 PM
mattyge's Avatar
mattyge
ok i got it off and replaced the wires etc but there was an extra wire in the box and idont know where it goes
Old Dec 27, 2006 | 04:56 PM
Glideman88's Avatar
Glideman88
Is it the new wire for the coil?
Old Dec 27, 2006 | 05:00 PM
kstroeher's Avatar
kstroeher
I think they all come with 2 coil wires, one with straight ends and one with 90 degree ends.
Old Dec 27, 2006 | 05:34 PM
1RewdRam's Avatar
1RewdRam
ORIGINAL: kstroeher
yep
Old Dec 27, 2006 | 05:35 PM
mattyge's Avatar
mattyge
yes i replaced the coil one that goes to the distributor it had 2 90degrees on it but theres another one with a 90 and a straight end
Old Dec 27, 2006 | 07:41 PM
mattyge's Avatar
mattyge
ok i think i got it figured out it's probably just a different ignition coil wire incase you got a different coil. Anyways runs much better with all the ignition parts replaced, cleaned the throttle body too, lots of gunk
