View Poll Results: A poll
Eelbrock IAS
31.58%
Rancho 9000
21.05%
Rancho 5000
5.26%
Bilstein 5100's
26.32%
Pro - comp
10.53%
sky jacker
5.26%
Voters: 19. You may not vote on this poll
Old Aug 7, 2015, 05:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
shock absorbers
Old Dec 28, 2006 | 08:36 PM
erikb45's Avatar
erikb45
Default shock absorbers
which shocks do you think are the best all around performance for the dollar?
Old Dec 29, 2006 | 04:04 PM
TMS Bill's Avatar
TMS Bill
Default RE: shock absorbers
This is one area of the truck that "best value" (Price v. Performance) is really irrelevant. The shocks can provide a "pretty good ride" and be dirt cheap ... but if YOU don't like them ... you'll be kicking yourself for buying and installing them. I was going the get the Rancho 9000's because they could be setfor a VERY firmride (where I like the better control provided). I settled for the IAS Performers because they were about $15 cheaper a corner. So I saved $60 bucks ... but the truck "floats" and has too much body roll in corners and excessive nose dive while stopping (for my taste).
I really think a better way to do this is to determinehow you want the truck to ride (soft and comfortable or firm with lots of road feedback) and ask how to best achieve THAT.
I still voted Rancho 9000's because you control the ride you getbased on how soft or firm you set them.
Old Dec 29, 2006 | 06:10 PM
HankL's Avatar
HankL
old shocks for Ram pickups post:
The Tenneco-owned Monroe brand Reflex shock is 'velocity sensitive valving'
design and said to be an attempted copy of the Edelbrock IAS. The $30 Reflex
is supposed to be softer for moderate on highway use.
Tenneco also owns Rancho, and sells a Reflex-like shock with stiffer valving
as the $53 Rancho model RSX for off roading.
http://www.a-1shocks.com/reflex/index.htm
http://www.monroe.com/Reflex_technology.htm
Quite a few people have said that the like the adjustability of the Rancho
model 9000 shocks. Most say that twisting the **** to adjust them is not hard
and can be done in less than 5 minutes, although some owners would like an
extended 'tool' to reach in and do it. Setting 2 is soft and 4 is rock hard.
I haven't heard of the 9000's leaking so much as the exterior rusting badly
after a few years. An extra coat of good urethane paint on each shock prior to
installation might help.
Explorer ProComp is now making a gas charged monowall 6-way adjustable shock
called the MX6.
{Tenneco used to make the ProComp shocks on their assembly line under
contract, but I don't know if that is true of the new shock design or not.}
The last time I looked at the ExplorerProcomp webpage they didn't
have the new 6-way adjustable shock written up yet, and as of May 2002 they
did not list any MX6 part numbers for Dodge Ram trucks, just Chevy and Ford.
http://www.explorerprocomp.com/shocks.html
I haven't heard as many good things about the Rancho 5000 shocks. They are
stiffer than the factory Ram shocks, but I have heard Ram owners who bought
5000 later say they wished they had gone with 9000s.
http://www.gorancho.com/products.stm
Delphi Automotive
(used to be AC Delco of GM but now independent)
has a $500 electronically controlled adjustable aftermarket shock system that
can be adjusted from the cab but does not need an air compressor. Delphi has
been demo'ing this at auto shows but I haven't seen an installation
personally.
http://www.delphiautomotive.com/
The Kenne Bell Company says that they tested all shocks for their specialty
decked out Rams and Durangos and decided upon the Bilstein.
Hotchkis Performance Suspensions also says the Bilstein is best for Rams and
Dakotas if handling is your main goal, and use this shock in their retro-fit
handling kits. The ride of the Bilstein is not supposed to be overly harsh on
pavement either.
http://www.bilstein.com/index2.html
http://www.kennebell.net
Sway A Way has some 'extra fat' shocks that have physically larger bodies and
rods for heavy duty off-road applications:
http://www.swayaway.com/Shock%20frameset.htm
Doetsch Tech 8000's on a Ram have had a favorable review from one Ram owner
who claims to have tried Rancho, Monroe, and Edelbrock previously. This is a
intermediate price, dual wall shock, with an large diameter body.
Gas charged KYB shocks have been reviewed as being good for cornering and
smooth twisty pavement in Ram pickup use, but very stiff on pot-holed city
streets.
In the cheap shock category, Gabriel LT VST's have been reported to do ok with
a ride generally on the soft side. They run anywhere from $16.99 to $25 each,
depending on if you can find them on sale.
http://www.gabriel.com
I have had the $79 list price Edelbrock IAS shocks on my 2wd 1500 Ram for
about 5 years & 70,000 miles now.
They improve the sway in corners,
reduce nose dive on braking,
and generally feel more in control
- but they are pretty stiff when new,
and the on-pavement ride suffers some
compared to the soft factory installed gas charged shocks designed to impress
potential buyers during on-highway test drives.
Don't believe the hype about 'luxury car' ride with the Edelbrock IAS, but the
bit about being able to go over speedbumps without 'buck & wave' afterwards is
indeed true.
Temperature seems to affect the IAS shock damping a little, with hot summer
days giving a softer ride than cold winter days.
On/Off road the control is good with almost no after pothole gyrations or
washboard road over-reaction.
I personally like the ride a little better now that my 4x2 Ram IAS shocks have
60K of wear on them versus the stiffer ride when they were brand new.
For off road driving several Ram owners have remarked that taking off the
Ram's front sway bar improves articulation and ride. The IAS shocks work well
without the sway bar off road and on pavement, perhaps because of their own
internal anti- sway valving. I have removed the anti-sway bar on my 1995 2wd
CC Ram and have felt a noticeable improvement in ride when one wheel hits a
bump that the other wheel does not. Body lean in turns is still low. I now
have a lot of experience without the sway bar and have personally found no
downside to removing it for the type of driving I do. (Before flaming me on
this I would ask that you read the sway bar links I list below)
If you buy the Edelbrock IAS for a Ram, watch to see that the steel bushings
inside the rear shock upper rubber bushings are there, otherwise you will need
to swap them in from the old factory shocks - the steel bushing keep you from
over-tightening the mounting bolts, which is important as the specified torque
on the mounting bolts is fairly high.
I also had to open up one of the front washer holes on the front IAS shocks to
get it to properly fit.
In addition to the $79 IAS
{there have been "buy 3 get the 4th free" and $25 mail in rebate programs
approximately 2 times per year}
Edelbrock is now selling a double wall and cheaper version shock - but I don't
see any advantage to the new design except low price. Monowall shocks are
generally superior.
http://www.edelbrock.com/automotive/ias_shocks.html
Note that if a lift for your Ram is in the future, any of these shocks may
need to be changed due to length, and any money spent now may be lost.
Other shock & suspension websites worth a visit:
http://www.shox.com/suppliers.html
http://www.tokicogasshocks.com/index.html
Also note the lightweight composite load leaf spring for Ram rear leaf
springs at the above Tokico website.
There is additional custom made fiberglass spring info at:
http://flex-a-form.com/
More shock links:
Some interesting Java calculators pertaining to shocks:
http://www.proshocks.com/calcs/
Sway Bar/Suspension links and explanations:
http://www.howstuffworks.com/question432.htm
http://mchambers.members.easyspace.com/swaybar.htm
http://www.teamscr.com/sway.htm
http://suspension.com/stam-bar.htm
Further Unusual Suspension mods for Rams & other off road vehicles:
http://www.kinetic.au.com/index.html
http://www.keldermanmfg.com/airride.htm
The "Roadmaster" top of spring control coil add-on below has gotten good
reviews so far from Ram and Dakota owners who have tried them:
http://www.activesuspension.com/
Velvet ride shackles have gotten mixed reviews on Rams. I haven't read a
single positive review of Velvet Rides on 1500 series Rams, but some 2500/3500
Ram owners have written that they 'help a little bit when unloaded.'
http://www.drivetrain.com/velvetrideinst.html
Old Dec 29, 2006 | 06:19 PM
1RewdRam's Avatar
1RewdRam
......... I think you forgot something there Hank ..............
Old Dec 29, 2006 | 07:06 PM
whiteram00's Avatar
whiteram00
i seen in another post a few days ago in here that these 94 to 01 ram sports ride rough unless you have a softer shock on them is that right?if so what is the softest shock,is it the monroe reflex,im looking for a cheap good shock
Old Dec 29, 2006 | 07:43 PM
erikb45's Avatar
erikb45
way to go hank - you can breathe now. lol
he promotes that the ias is a great shock, keeping in mind that he has 2wd- his harsh ride mgiht be a little softer (better) for us 4wd' ers. i have not heard any bad news about the ias by edelbrock, sounds like a smart choice for me
Old Mar 19, 2007 | 11:46 PM
lauren_24's Avatar
lauren_24
I think i'll be getting dodge rancho shocks. i heard more about its performance and looks okay to me. Anyone tried rancho? can anyone give me more feedbacks on this item?
Old Mar 20, 2007 | 04:21 AM
Rusty Nurf Bar's Avatar
Rusty Nurf Bar
Sounds like you made up your mind but just in case, I love my skyjack lift and it does great off road but on road drive sme insane how stiff it is
