Cost of regearing?
Old Dec 29, 2006 | 02:17 AM
ripto's Avatar
ripto
Default Cost of regearing?
I do realize the best way to get that low end power I'm looking for with my 285's is to re-gear the truck from stock 3.55 to 4.10 (maybe a step higher but I don't really see that being necessary in the near future). Would you say 4.10 and 285's would bring me to stock setup, slightly worse that stock (slower acceleration), or slightly better than stock? What would the next step up be, 4.56? Anyway, from all of you who have had this done, how much did you have to pay, for the whole thing, parts and labor? I've heard it's a tough job so I figure most have had a shop do it for them. Did you buy the gears yourself and bring them to the shop or just told them what you wanted? I'm still not really crazy about going to 265's at the next tire change (few years from now most likely), they do seem kinda small. I would really like to get a nice aggresive looking 285 with (wait, I will get this right) lower gears? 4.10 most likely. Should be better for normal driving, how will it affect highway driving compared to my stock 3.55 gears?
Old Dec 29, 2006 | 11:14 AM
moparrtguy's Avatar
moparrtguy
Default RE: Cost of regearing?
ORIGINAL: ripto
I was quoted $3000 parts and laborreplacing my 3.55 with4.56 front and rear with Yukon gears. That included replacing the open carrier in the rear with a limited slip. I would say that 4.10 should work well with the 285 tires, that is the setup that the off road package trucks come with. Plan on spending about $1000 per axle just for the gear change.
Old Dec 29, 2006 | 11:26 AM
GOD RAM IT's Avatar
GOD RAM IT
$500 an axle for regearing is the norm. I wouldnt pay more than that. the rear is a piece of cake to regear.
3K sounds high. no more than 1K for parts. I would try and get the parts yourself.
price the stuff at DC4wd or DTS
Old Dec 29, 2006 | 11:54 AM
Chopper1's Avatar
Chopper1
I would agree with the 500. per axle. The guy that did mine still gave me the 1 year warranty since the parts were new and he said were good stuff. Some shops will not warranty stuff if you don't buy it through them. As GOD said, research the parts prices first and see if they are going to rape you on mark up or willwarranty the work if you get the parts.
I spent $1100. on parts, front and rear gears, front and rear full install kits, rear posi unit.
http://www.drivetrainspecialists.com/
Then$1000. on labor and 2 new rear axles.
4.10 will do well for an overall gear. Would not go to 4.56 unless you are going over 35" in tires or serious pulling/mudding
$3000. #@*#@ OUCH. Check with someone else. Hope the same guy is not doing other maintenance at those prices.
Old Dec 29, 2006 | 07:27 PM
moparrtguy's Avatar
moparrtguy
I had a feeling that guy was ripping me off. I came up with the same $1100 price for parts when I figured it out later at home. $2000 for labor and I knew he was taking me. I am going to get some more quotes before I make the change.
Old Dec 30, 2006 | 12:02 AM
Aubrey's Avatar
Aubrey
I agree with 4.10s for you.
As for price, the cheapest I could find around here was 4-Wheel Parts. I went from 3.55 to 4.56 with an Ox in front and an Auburn in the rear. My total was $2045. I don't think you need a new carrier with a 4.10 but when you go to 4.56 it requires new ones. So your price will still be lower.
Old Dec 30, 2006 | 12:13 AM
moparrtguy's Avatar
moparrtguy
ORIGINAL: Aubrey
Whymust youchange the carrier with 4.56 in the rear?
Old Dec 30, 2006 | 01:56 AM
Aubrey's Avatar
Aubrey
I don't know for sure but it must be a big enough change in gear size. The Auburn is a different part number for up to one size (I think it's 4.10) and another for up the next step (4.56). The gear sets was something similar. If I went to 4.10 and no traction device it was one thing but to go to a 4.56 it was a other animal but since I was putting in the Ox and the Auburn, the install of those (new carriers) worked into the install price.
Old Dec 30, 2006 | 03:50 AM
dsertdog56's Avatar
dsertdog56
I'm confused....you do not need to change the rear carrier on a 9.25 diff when going to a lower gear. The Auburn LSD is an all new carrier any way,
You WILL need to change the carrier in your front axle, because the ring gear on 4:10 and lower ratio sets is thinner than your 3:55s...Did your mechanic include that in your estimate? BTW if you can find a set of 3:92 gears, they will bolt to your stock 3:55 carrier, I doubt you'll notice a difference between them and 4:10s.
If you decide to do the swap to 4:10s or 4:56s, I happen to have the correct carrier availible...
Old Dec 30, 2006 | 03:51 AM
steve05ram360's Avatar
steve05ram360
with 285's 4.10's is the way to go... it ran me $1450 to re-gear and add posi...
