Put in the rear bilsteins
Old Jan 5, 2007 | 07:43 PM
  #31
IndyRamMan's Avatar
IndyRamMan
Default RE: Put in the rear bilsteins
ORIGINAL: RM_Indy
Unfortunately you need to have shorter shocks (compressed/extended) when you lower your truck so the Bilsteins wont work depending on the specs. I have2x4 drop with stock rims/rubber & 3x5.5 on my race rims/rubber. For shocks Im using the so so Nitro Drops at 4 corners and Comp Engineerings 3 way adj drag shocks up front for track use (modified/intended for mid 90 camaro)
Couple links to sway bars
http://www.suspensionconnection.com/...tion/to=r.html
http://accessory-center.com/Sway-Bar-Link-Kits.ctml
http://www.stylinconcepts.com/parts..../categoryid/30
Eurethane bushings can help reduce body roll as well though they can be a bit noisey.
Tires with a higher traction rating will improve cornering but at the cost of decreased lifespan
yea, it sucks that id haveto replace the shocks again.
Ill take a look at the sway bars. I doubt ill lower the truck. A-i dont like the way a lowered truck feels. B-i dont care for all out performance. Its daily driver first and foremost. Eurethane bushings were also on my thought process, but i dont know if its going to be worth the gain for the lack of comfort. Thanks for the links. Btw, whats the dia. of the stock bars? The tires i have now have an A traction rating i believe. 110 load, V speed. A trac, A temp, 420 treadwear. Thats what I have upfront. Same specs and 10 mm wider in the back. Thinking of getting a dot drag radial for the rears, as the weather is pritty unchanging this year.
Old Jan 5, 2007 | 09:23 PM
  #32
bamory's Avatar
bamory
Why drop it, you live ina ghetto?
Old Jan 5, 2007 | 11:18 PM
  #33
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: bamory
i have the same feelings, but...when you do it for actual gains rather than athsteticis (however its spelled) its another thing. though i dont really think ill be doing it even though i like the idea
Old Jan 6, 2007 | 12:50 AM
  #34
Ram_Sport's Avatar
Ram_Sport
i just wanted to say this, i read it up top and skiped everything else, i think it should be Self Appointed Crusaders of Safety aka SACS ok sry just playing around
Old Jan 8, 2007 | 08:01 PM
  #35
TMS Bill's Avatar
TMS Bill
How about Self Appointed Crusading Knighthoodof Safety aka SACKS?
... SACS works too.
Old Jan 8, 2007 | 09:55 PM
  #36
moj0's Avatar
moj0
ORIGINAL: bamory
You can play........but sliding your truck on a public road, while going 100-110 is just plain idiotic, I don't care how good your so called ability is. As Fire/EMS, I see peoples abilities wrapped around utility poles, or rolled 6-8 times across fields, or the worse ones like missing a curve and going through a house and killing a child.
Grow up
::nods head::
as a state trooper, i have also seen what can happen after stuf like that..
HOWEVER...heheh i sold my honda s2000 for the ram i own now. and lemme tell yah, i drove that honda like i was johnny tran!!
i did some crazy shtuffz..yes i did
Old Jan 9, 2007 | 04:04 AM
  #37
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: moj0
ORIGINAL: bamory
You can play........but sliding your truck on a public road, while going 100-110 is just plain idiotic, I don't care how good your so called ability is. As Fire/EMS, I see peoples abilities wrapped around utility poles, or rolled 6-8 times across fields, or the worse ones like missing a curve and going through a house andkilling a child.
Grow up
::nods head::
be careful, you might get pwned by the pigs...i mean, eghhh ::tight coller:: ;D
