Collapsed Lifter
Old Dec 29, 2006 | 12:48 PM
hicktown's Avatar
hicktown
Default Collapsed Lifter
Ive had this ticking noise for almost a year now and im losing my mind. My engine hasnt had any problems so far and its ran great. Im going to take it to the shop here pretty soon, but how much would it cost to replace a lifter?
Is this a common problem with 01 ram's?
hick
Old Dec 29, 2006 | 01:42 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Collapsed Lifter
I have a lifter doing the exact same thing and I just rebuilt my engine. The damn thing ticks at odd intervals. I dumped some Marvel Mystery Oil in the crankcase in hopes of freeing it, but to no avail. I'm planning to upgrade to the 1.7 rockers and will install new lifters when I do so. If you know which lifter it is, just do it yourself.
Old Dec 29, 2006 | 09:12 PM
DADDIEMIKE's Avatar
DADDIEMIKE
YOU CAN ALSO SUBSTITUTE 1/2 QT OF TRANS FLUID FOR OIL . SOME TIME THE TRANS FLUID WILL GET IN THE LIFTER BETTER THAN THE OIL AND PUMP IT UP. I'VE DONEIT A COUPLE TIMES ON A FORD 2.9L V6 AND HAVE HAD GOOD LUCK.
Old Dec 29, 2006 | 09:22 PM
timwag2001's Avatar
timwag2001
ive got a little bit of lifter noise but its not that bad as to where i can hear it in the cab. i did have a ticking noise that was a couple of spark plug wires and my coil wire arcing
Old Dec 30, 2006 | 03:57 AM
steve05ram360's Avatar
steve05ram360
try substituting the quart of MMO in there and see if it fixes it. if not, swap them all, they arent that expensive if you go with the stockers.. if you want to upgrade, the rhodes standard ones would be a good replacement... you would need adjustable rockers though...
Old Dec 30, 2006 | 04:49 PM
turkeyhunter1962's Avatar
turkeyhunter1962
I am getting ready to do the complete change of my roller lifters, pushrods, and Harland Sharp 1.6 Roller Rockers. Already have a performance cam so I decided against 1.7 RR's.
I am also pulling my timing chain and gears and installing the new chain tensioner. I have heard that this will eliminate any noise from the chain and make it last longer.
I'll take a few pictures of the work and post them when I am done. I'll also let you know what problems I encountered.
Old Jan 9, 2007 | 11:57 AM
hicktown's Avatar
hicktown
i threw some marvel oil in and it seemed to quiet the noise substantially, but that lasted onlya few weeks. [:@]
Old Jan 9, 2007 | 01:37 PM
steve05ram360
well a couple of other suggestions then... 1) use a heavier weight oil with the MMO or 2) swap you lifters when you
do your plenum pan fix (if it still needs to be done).
the better solution is to swap the lifters with rhoads liftersand go to adjustable roller rockers.
Old Jan 10, 2007 | 02:01 PM
hicktown's Avatar
hicktown
What weight oil do you suggest? i believe i use 5w 30 synthetic. actually what im thinking is swaping my 239ci for a 318sc or a stock 360 when my mileage gets up there. im at 80k right now. or i could just leave it be. we'll see.
Old Jan 10, 2007 | 02:10 PM
steve05ram360
try 20w-50 1st w/mmo and see how it does. if you end up having to swap the lifter, you can figure out which one has the problem... you'd have to yank the intake manifold and crank the motor until all the lifters are primed & pumped up, then you can see which one is not pumping up.
another Q I have is how long have you owned it? it could be that you have a lot of gunk on the inside of the motor and it still needs to be flushed out... how many miles has the MMO been in there?
