Lousy Headlights
Old Jan 16, 2007 | 12:00 AM
10sec440's Avatar
10sec440
Default Lousy Headlights
Hi all, first post here! I have a 2000 Ram and the headlights are quite crappy. My GF has a 99 Durango and they are quite similar lights and they are not good either. My question is, is this a normal thing for these trucks or maybe I need new housings? I'm thinking the reflectors have gone out of them. you can barely see where you are going at night. Would'nt want to spend the dough and have them the same. Thanks, Chris.
Old Jan 16, 2007 | 01:30 AM
akyne's Avatar
akyne
Default RE: Lousy Headlights
The standard headlights on these trucks are all crappy. The best mod for the money is to get the headlight assembly out of a Sport model Ram as they came with two headlight bulbs per side as opposed to the standard one. You'll need to uprgrade the wiring harness as well to fit the four lights. Check out http://www.lmctruck.com to see what I'm talking about.
Old Jan 16, 2007 | 01:36 AM
jnellydodge's Avatar
jnellydodge
Probably a dumb question but have you simply tried replacing the bulbs with some high quality ones?
Old Jan 16, 2007 | 01:48 AM
dishdude2k's Avatar
dishdude2k
one other thing to check.. i found this out on mine.. is there are more than one fuse for EACH headlite in the ram / durango.. look under the hood in the power box next to the battery.. you will find one for the left headlight and the right headlight.. if one of them is blown.. or both.. your lights will work.. but they will be very dim.. check em.. turn on your lights then pull one at a time.. if it goes even more dim.. they are still good.. try the bulbs.. if there is a cloud over the housing.. try to use like a 400 grit sandpaper and wet sand it.. be careful.. but you can get it looking alot better. .my option would be.. hey this is a great excuse to put some new lights on it (ebay has an awesome set of halo projection headlights for like 150 bucks)
Old Jan 16, 2007 | 02:40 AM
sciroccotune's Avatar
sciroccotune
has anyone checked the power to the units? if the Voltage is low the light will be dim. Im gonna chack when i get a chance.
if this is the case i will be able to make a upgraded loom to correct this and run the lights directlt off the batt for full 12v.
Old Jan 17, 2007 | 04:35 AM
sciroccotune
well just FYI i tested the lights today and there is (sadly) a very low loss of power, the voltage is not far off the bat V. this means no easy fix for use non sport owners.
oh well never mind
Old Jan 18, 2007 | 12:30 AM
Aubrey's Avatar
Aubrey
Does anyone know if you can tap into the headlight wiring (as well as the reverse light wiring) for auxillary lights without causing any low voltage issues?
Old Jan 18, 2007 | 01:44 AM
Ram1500Dodge's Avatar
Ram1500Dodge
i wouldnt....its fairly easy to run wiring for aux lights...i know it sounds easier to just tap in, but that may cause electrical issues down the road
Old Jan 20, 2007 | 02:14 AM
10sec440's Avatar
10sec440
Thanks for the replies! I agree I wouldn't tap into the headlight circuit.
