Oil leak...
Old Jan 16, 2007 | 09:53 PM
NOMORECHEVY's Avatar
NOMORECHEVY
Default Oil leak...
After driving and parking my 1998 Dodge Ram 1500 (5.2)pick up truckI have noticed a small transmission fluid leak coming from the top (engine and trans area), between trans cage and oil pan, leaving a dot the size of a qurter on my driveway. That's the only place leaking, everythinig elseis dry all around. Any idea of what's going on??
Old Jan 16, 2007 | 11:00 PM
mattyge's Avatar
mattyge
Default RE: Oil leak...
must be the gasket, if your worried about it try putting some silicone on it
Old Jan 18, 2007 | 06:26 PM
NOMORECHEVY
Since nobody but one member onlyresponded tothe leaking problem between engine and trans area in my truck,I assumedmany arenot familiar with the problem and that's why Iwill like to post the following information for future referenceor members trying to find out a solutionto the same problem.
According to a Dodge Dealer tech,theleak is caused due to a damage front trans pumpallowing fluid toescape or leak. Solution to the problem........would need to be resealed and in order to replace/resealed, trans has to be removed....ohh[sm=noooo.gif]
How much?..... $780.00 plus tax on the parts. [:@]OUCH!!
Well, I decide to pass and declined the repair at this time. According to the tech, and since the leak is minor, I cancontinue driving it as long as Ikeep checking the level and adding fluid once or twicea month. I think I will do thatuntil I trade it in for a newer truck.......[sm=icon_cheers.gif]
