Headlight went out, any suggestions?
Old Jan 21, 2007 | 05:21 PM
ripto's Avatar
ripto
Default Headlight went out, any suggestions?
Last night I was following some friends and when we got to where we were going they told me my left headlight was out. I drove with it out home but when I got home I got out and tapped the cover about 4 times and it came back on. Any thing I need to know when trying to take off the cover? I have the 01 manual from the x-mas thread to go by but wondering if there was anything else. Could there be something wrong with the wiring itself? If theres something wrong with the bulb, is there a certain type I should buy to replace them?
Old Jan 21, 2007 | 08:59 PM
rollerstud98's Avatar
rollerstud98
Default RE: Headlight went out, any suggestions?
i had the same problem with mine, it was just the light itself, you dont need to take the cover off, just pop the hood, and pull the light out the back, go to any automotive store and tell them you need to replace your headlight bulb and they'll be able to give you the one you need
Old Jan 21, 2007 | 09:25 PM
Sinister's Avatar
Sinister
its either 9004 or 9007 I forget which, replacing bulbs are quite easy, and like rs98 said, just pop the hood and pull the light out, if you have a grey clip that locks onto the bulb keeping it in place, it turns counterclockwise to unlock it.
Old Jan 21, 2007 | 09:33 PM
hicktown's Avatar
hicktown
Had the same problem. Your filaments in the bulb are going out. Just replace them with some hid or ultra white lights.
Old Jan 21, 2007 | 11:48 PM
mikecjn's Avatar
mikecjn
Just as a suggestion...when I have a headlight or tail light go on me I usually will replace both and keep the one that was still working stashed in the glove box or under the rear seat. When one goes...the other has the same amount of hours on it and isn't very far behind.
Old Jan 21, 2007 | 11:56 PM
Gone Campin's Avatar
Gone Campin
ORIGINAL: mikecjn
I do this also, and I wear some sort of gloves to keep oils from skin off of halo bulb - can shorten life I think.
Old Jan 22, 2007 | 12:38 AM
ripto's Avatar
ripto
Ok cool I will check it out tomorrow, thanks.
Old Jan 22, 2007 | 12:51 AM
97rammn's Avatar
97rammn
gone campin is right dont touch the glass on the bulb
Old Jan 22, 2007 | 01:42 PM
steve05ram360's Avatar
steve05ram360
you also might look into a heavy duty bulb... they have a thicker filiment IIRC...
Old Jan 23, 2007 | 02:25 AM
ripto's Avatar
ripto
I was looking at it today, do I have to take the battery out to get to the driver side light bulb? Doesn't seem like there is room there.
