Torque Converter P1740 Code
Old Jan 23, 2007 | 09:45 PM
dodge_ram_guy's Avatar
dodge_ram_guy
Default Torque Converter P1740 Code
Hey all,
I have a 2000 1500 4x4 with the 5.9 and 80K miles...
My CEL came on and Autozone gave me a troublecode OBDII P1740: torque converter clutch inductive signature malfunction.
Dealer told me that this was very common in these trucks and that my transmission had to be rebuilt to solve the problem! Please tell me this is not true. Does anyone have any advice for a do-it-yourselfer?
Also, I've noticed this winter that when I put my truck in 4wheel it sounds like some bearings are going out in the transfer case...is this common on a truck with only 80K miles?
Thanks,
Andy
Old Jan 23, 2007 | 09:47 PM
Sirhilton17's Avatar
Sirhilton17
Default RE: Torque Converter P1740 Code
I dont know, but it seems to be happening to alot of people...
Maybe the whole thing about dodes having weak trannys is true...
Old Jan 23, 2007 | 10:40 PM
baltimore's Avatar
baltimore
my P1740 cel is on now. i bought my 01 4x4 last month and the light came on a few miles from the dealer. i took it back there and they changed a valve body plate now it slips at low speeds. they are looking into it and there machanic says they are going to replace the converter and all the solenoids. how expensive i do not know, but from what i hear you can do it yourself. i am going to there shop tomorrow and i will update my P1740 to you then
Old Jan 23, 2007 | 11:30 PM
TMS Bill's Avatar
TMS Bill
No rebuild necessary ... there's a TSB on this: http://dodgeram.info/tsb/2000/21-11-00.htm
Old Jan 24, 2007 | 12:07 AM
SnoPro Dodge's Avatar
SnoPro Dodge
I've had this code coming up for a year. Truck does'nt seem to run any different when it's on. I did get a new plate from dealer but don't know where it goes inside. Anybody know where it's at, how deep do you gotta go?
Old Jan 24, 2007 | 01:04 AM
baltimore's Avatar
baltimore
the plate goes on the valve boby, fom what i understand you need to pull the pan filter and valve body and the plate goes on the valve body. about 2 hours worth of work. but when my plate was changed out my trans now slips from 1st to 2nd
Old Jan 24, 2007 | 03:26 AM
gta91's Avatar
gta91
WoW, I am having this issue right now myself, 2001 Ram.
I did how ever just finish installation of the Transgo Shift Kit, about 2 weeks later, I got the CEL.
I am told by one Mechanic (Friend) that the Torque Converter needs to be replaced, and the issue will go away. He says this be cause the TCC Stall test fails to stall the engine.
I have another Mechanic (2nd Opinion) telling me the Torque Converter does NOT need to be replace. This mechanic is contacting a friend (engineer) at transgo, for opinions from them.
I tell ya, if someone could tell me, what would be a good upgrade to the 46RE, to eliminate this code, yet strengthen its abilities. I would listen..
Old Jan 24, 2007 | 09:17 AM
SnoPro Dodge
Has anyone else had the slipping problem after the plate update? I think I'll leave mine alone until we get this figured out more. I assume that all the trannies after the tsb date were updated when built new at the factory. The newer trucks should be fine then? Keep us updated on your situations guys. Thanks!
Old Jan 24, 2007 | 10:41 PM
baltimore's Avatar
baltimore
well my truck goes in thursday of next week and they are rebuilding it. now i do not know the extent of "rebuilding" but the machanic has been truthful with me and i believe what he tells me, but i think he is replaceing the solenoids and coverter. I'll let you know when i know
Old Jan 25, 2007 | 12:55 AM
dodge_ram_guy
Thank you all for all you info!
My truck hasn't been running or preforming any differently since the code popped up and according to your responses I think I'll leave it alone until a surefire fix is found.
