Truck won't idle with electrical load.
Old Feb 6, 2007 | 10:03 PM
spo999's Avatar
spo999
Default RE: Truck won't idle with electrical load.
No luck, problem persists with fuses pulled.
Old Feb 7, 2007 | 01:31 AM
radwebster's Avatar
radwebster
that means the problem lies in the system before the fuses, so at the switch or relay, depending on what youre looking at. did you try a new battery? or clean up and reattach the battery terminals?
Old Feb 7, 2007 | 01:06 PM
spo999's Avatar
spo999
Went out and started pulling more fuses today, pulled the power amp 10Afuse in the drivers side dash fuse panel and the problem cleared, however when I put the fuse back in the problem did not come back. Not sure if this reset something or if it was coincidental. My wiring diagrams in my Haynes manual are pretty generic, does anybody know what the fuse titled 'power amp' controls?
Old Feb 7, 2007 | 02:54 PM
TMS Bill's Avatar
TMS Bill
I work on airborne electronics for the Air Force. You would not believe how many times I've signed off a write-up with "Re-seated (whatever) component ... ops check good".
I troubleshoot down to a bad circuit card assembly ... replace it ... checks good. Just to make sure, I reinstall the "bad" card ... works fine. Re-seat.
Old Feb 7, 2007 | 07:02 PM
shott8283's Avatar
shott8283
ORIGINAL: TMS Bill
SSOOO funny you say that.. when i was in the Corps, I was an aircraft mechanic.. and ive sighn off ALOT of writeups (MAFS) stating "removed and reinstalled X component, elec check 5.0" or " system was left in O F F postion" or "removed and replace pilot, system checks 5.0" or something dumb to that nature..to let the pilots know they are just smart morons
anyway ... back to the truck
my truck did the same EXACT thing when my batter was going and/or it was wicked cold out.. i did two things.. replaced the battery AND the battery terminals.. i know autozone checked the battery,,but i also took my old stock mopar battery into them and had them check it and they said it was fine too.. but not even 2 days of having the old battery out .. i had it in the back of the truck b/c i was too lazy to get rid of it and i used it to jump another car and it wouldnt even crank over a 4 cylinder honda...
14.4V is the magic number.. if your hitting that when the motor is running then your ALT is perfectly fine!!! its normal for 12V system to run at 14.4V's
hope this helps!
Old Feb 7, 2007 | 11:25 PM
mattyge's Avatar
mattyge
mine runs around 16.5v is that ok?
Old Feb 7, 2007 | 11:52 PM
DieselDemon's Avatar
DieselDemon
ORIGINAL: mattyge
16.5 on the truck gauge?..or 16.5 on an actual multimeter.
If the multimeter's battery is not dead, then 16.5 is high. Could be a bad battery cell as well.
I run 14.4 max. That's what most equipment is designed around as a max operating voltage in automotive applications.
