Anyone made there own CAD bypass
Old Feb 1, 2007 | 11:49 PM
Terran's Avatar
Terran
Default RE: Anyone made there own CAD bypass
what does a posi-lok look liek installed?
Old Feb 2, 2007 | 06:01 AM
zique's Avatar
zique
Look at Tani's post of it here here it has some pictures of it installed. One of dhvaughan's posts has a link to one as well.
Old Jan 6, 2011 | 04:47 PM
maloney's Avatar
maloney
Default cad bypass
i just did a cable bypass and it takes longer to wait for the jb weld to set up then anything if anyone need to no how todo this you can e mail me maloney_1414@hotmail.com
Old Jan 6, 2011 | 11:19 PM
dhvaughan's Avatar
dhvaughan
^umm. why don't you just post it.
Old Jan 6, 2011 | 11:55 PM
matty675's Avatar
matty675
IMO the oem vac setup is really not hard to get working properly.
verify that you have 17" at the red line in 2wd and 17" at the black line in 4wd. if there is a problem in the CAD, switching to posi will do you no good.
Old Jan 7, 2011 | 07:03 AM
dhvaughan's Avatar
dhvaughan
no, its not hard. but after about the 2nd or 3rd repair - it gets old.
go posilok and be done with it forever.
this is a really old thread. its got everybody except HankL in it.
Old Mar 3, 2011 | 07:55 AM
Cactus625's Avatar
Cactus625
I had the same problem with my CAD system. I removed the CAD unit, took off the retainers, moved the fork over to the left, reinstalled the retainers to hold the fork in place. I moved the collar over to the left to engage(lock) the axle and reinstalled the the CAD housing. This locks the axle just as in a full time system or as what would happen when you lock in manual hubs. I did this about 6 months ago and have not had anything bad happen as of this writing. I don't have a light to indicate it's in 4x4 but I don't need it anyways.....just look at the shifter on the floor. This only cost me about 15-30 minutes of my time and no cash out of pocket. Have not noticed any difference in mileage or handling. I think that the CAD system is an afterthought on the designers part and they should have just gone with the tried and trued system of lock out hubs. It maybe old school but it is still the best,IMO.
If anyone has any other ideas for a cheap fix on this or has done what I did and had adverse reactions please let me know b-4 I really screw something up!
I am new to this site and I must compliment all of you on the wealth of knowledge and helpfullness available on this site. IMO this is THE BEST SITE and I'm happy to be part of it!!!!!!!
Old Jan 12, 2018 | 11:36 PM
Wh1t3L1ghtn1ing's Avatar
Wh1t3L1ghtn1ing
Default Cad
Hi everyone i know this a quite old thread but id like some info for myself. i bought a 97 dodge ram 1500 4x4 and iv'e seen these people bypassing the vacuum systems (the ****tiest design ever made by dodge) well anyways when i engage my 4x4 the light does not come on and after maybe say i'm doing 50 on the hwy it will finally engage(still no light, maybe be burnt out or something isnt working right). but as soon as i slow down it will disengage. if i'm stuck in some stuff lets say snow and i put it in 4x4 and really start getting into the throttle it will click in and get me out real quick then take a **** on me. i want to know if this is caused by my vacuum lines. if so i'm just going to bypass it with a video i saw on YouTube that didn't seem to bad of an idea. or if it may be something else.
Thanks for your help, Wh1t3L1ghtn1ng
Old Jan 13, 2018 | 03:32 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
That's an odd problem usually it's the opposite. The higher the RPMs the less vacuum created
Old Jan 13, 2018 | 08:31 AM
I don't think thats a vacuum problem. Likely the bushings in there are worn, so the axles are not aligned properly. I would be tempted to pull the housing, and see what's going on. Careful though, the bolts like to break.
