4wd light flickers in 2wd, gos on and off.
Old Feb 1, 2007 | 04:09 PM
damageddakota's Avatar
damageddakota
Default 4wd light flickers in 2wd, gos on and off.
i just replaced the trans with a reman. and the 4wd light flickers and comes on when i drive. but its not in 4wd. is there a problem?
Old Feb 1, 2007 | 04:14 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: 4wd light flickers in 2wd, gos on and off.
Mine did that when I had a vacuum leak in the system. It flickered at the speed of the vehicle, and would be light or off when at a stop.
Old Feb 1, 2007 | 06:52 PM
ddog737374's Avatar
ddog737374
yea mine had a Vacuum leaktoo but only whenI turned a corner the light would go on it was right by my transI just bought a coupling from pepboys and fixed it.
Old Feb 2, 2007 | 12:09 PM
k12allen's Avatar
k12allen
That 4WD light is turned on by a microswitch in the CAD - vacuum operated thingy in back if front axle. Lotsa people here know way more than me, but I think flickering light means the CAD is engaging/letting loose all the time. Don't think that's good.
My guess is a damanged/loose/leaking vacuum line - caused or made worse when tranny was changed.
Good thing is it should be easy to find and fix.
Bad thing is that it's NG to br going in and out od engagement like that.
Old Feb 2, 2007 | 05:25 PM
Sirhilton17's Avatar
Sirhilton17
Mine will somtimes flicker when I take it out of 4wd, but then its always off when its in 2wd...
Is it mean I have a vaccum leak if it flickers when coming out of 4wd? It only flickers maybe 5 times quick, then its gone.
Old Feb 2, 2007 | 07:26 PM
k12allen's Avatar
k12allen
My guess is not pulling shift fork to release the right axle shaft right away.Understand a delay in lightcoming on - collar hasto align before linking up. But unlocking should happen fully right away. I think blinking after going to 2WD is not a good thing.
Allen
Old Feb 5, 2007 | 02:42 AM
stevejh's Avatar
stevejh
Can someone post pictures of where these vacuum lines are, mines doing the same thing now that ive had the tranny rebuilt and id like to see if thats the problem.
Old Feb 5, 2007 | 02:55 AM
dhvaughan's Avatar
dhvaughan
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Feb 6, 2007 | 01:13 AM
stevejh's Avatar
stevejh
I found the problem, i had a break in the metal line. I used a brass coupling with pressure sleeves and its back to good.
Ill post pictures of it tommorow. I just cut out the torn put with a pipe cutter and used the coupling and some thread-lock to fix it.
