posi pics
Old Feb 3, 2007 | 10:52 PM
damageddakota's Avatar
damageddakota
Default RE: posi pics
what other parts do you have i need a ton and i am verry close.
Old Feb 3, 2007 | 11:44 PM
Tani1500's Avatar
Tani1500
just a heads up, your 2001 will have bigger brakes and also bigger bolts for the front axle control arms. some other stuff might also be diferent as i believe they switched steering set up.
Old Feb 4, 2007 | 12:16 AM
pashtrd's Avatar
pashtrd
All that is left of the 1995 is the cab,door/hood hingesHVAC box and the carpet. along with the axles.
Old Feb 4, 2007 | 12:20 AM
pashtrd's Avatar
pashtrd
has anyone here done this swap? 95 axles into 2001 truck? how many little"problems" am i looking at?
I am planning on doing the swap next weekend, but i cant afford to be without my truck for any period of time due to a "little problem"
my other option is to simply install the lift i have and leave the axles alone[:@]
I really want the posi for the rear of mine, and the 3.92 gears would be sweet, with the 35's i am installing.
Thanks
Matt
Old Feb 4, 2007 | 12:38 PM
pashtrd's Avatar
pashtrd
Tani1500,
according to Autozone's website, Both trucks 1995, and 2001 use brake rotor #5394
Both trucks 1995 and 2001 use upper bushing #FB543 ,and lower bushing FB735
Napa online lists 2 different rotors one 11.61" one 12.11"
lower bushing are the same, uppers are different.
what gives?
I am planning on using the contriol arms from the 1995 (they are aftermarket)
and the brakes from the 2001? will that work?
Old Feb 8, 2007 | 01:24 AM
pashtrd's Avatar
pashtrd
anyone have any info on what i am planning on doing? the weekend is coming up quick
Thanks
Matt
