Too cold for overdrive?
Old Feb 5, 2007 | 03:20 AM
mdrohman's Avatar
mdrohman
Default Too cold for overdrive?
I read the owners manual and it says that overdrive will only kick in when the transmission reaches a certain temperature. My truck sat for a day and a half in below zero temps then I went to drive it today while it was -10 degrees and my o/d never kicked in. The truck was well warmed up (temp gauge read around 215, which is a different problem - its always read high). I figured either the engine or the 1/2 hour drive (at 70) would warm things up but maybe not at 10 below? Has anyone heard of anything like this?
Thanks
Matt
Old Feb 5, 2007 | 06:27 AM
radwebster's Avatar
radwebster
Default RE: Too cold for overdrive?
it will never go into OD when its a certain temperature or belowout. its like 2 degrees or something close.
Old Feb 5, 2007 | 09:22 AM
Glideman88's Avatar
Glideman88
Sounds like your truck is working just the way it should. This is straight from the 2001 Owners Manual:
"NOTE: If the vehicle is started in ambient temperatures of -5F (-21C) or below, the transmission will not shift into Overdrive. Normal Overdrive operation will resume when the ambient temperature has risen to approximately 2F (-17C). "
Old Feb 5, 2007 | 08:18 PM
mdrohman's Avatar
mdrohman
I had no idea the overdrive had to do with the outside temp. Thanks for the info.
Matt
Old Feb 5, 2007 | 08:25 PM
DieselDemon's Avatar
DieselDemon
My tc will not lockup in cold temps. It usually takes 1-3 miles to warm up the tranny enough where the sensor finally gives the signal for OD and lockup.
If the air temp is 0 degrees outside and you have driven 10 miles, that should be plenty to warm the tranny up and allow OD and tc lockup.
I may be wrong.....wouldn't be the 1st time...LOL.
Good luck with your ride.
Old Feb 5, 2007 | 08:27 PM
jnellydodge's Avatar
jnellydodge
I asked this exact same question a couple weeks ago. It was below zero and truck never went into O/D. Its now above zero and it goes into O/D. Its normal.
Old Feb 5, 2007 | 11:00 PM
bamory's Avatar
bamory
It is like -2 here with wind chills to -25, my truck does the same thing even with the new tranny, glad to see that the safety feature is working properly.
Old Feb 6, 2007 | 05:12 PM
DuranguenzeRam's Avatar
DuranguenzeRam
Have the same issue here in the windy city but pardon my ignorance why is it a safety feature? The first day it happened cars where zooming by me and truck was just accelarating very very very very slowly....
Old Feb 6, 2007 | 09:54 PM
YOOPER96's Avatar
YOOPER96
Yes it is perfectly normal. Mine did the same thing on a road trip when it was -25. I had just bought the truck and I thought something was wrong until I checked the owners manual. Worked fine as soon as the temp. warmed up a bit.
