Mods to help a 1500 pull 14k LBS??
Old Nov 8, 2010 | 02:12 PM
  #91
Originally Posted by Gerehead8
You still won't have the 3/4 ton or 1-ton frame though and even if you do swap the drivetrain over the courts may not see it your way.
True that.
For pulling heavy loads, having the right vehicle for the task is the only way to do it safely. Trying to pull more than your vehicle is rated for, is just a recipe for disaster. Truck manufacturers give weight ratings for a REASON. Exceeding them is just going to get you in trouble, or get someone killed. Not a good plan.
