newbie with knock question
Old Feb 12, 2007 | 12:40 AM
nuch's Avatar
nuch
Default newbie with knock question
Yes I searched....I am new to the forum, been a Jeep guy for awhile and recently bought a 99 1500, 4x4 w/the 360. The 360 is the issue, has a knock I have read about others having. My question is this, it only knocks when the engine is warm. I just noticed it because I usually warm it up first but took off in a hurry yesterday in the cold, no knock. Once it warmed up knocked like hell. I am also using some oil, not sure how much yet since I have only had it a little while. Any help would be appreciated, cause other than the knock I love the truck. Thanks
Old Feb 12, 2007 | 12:54 AM
mattyge's Avatar
mattyge
Default RE: newbie with knock question
that would be your plenum gasket, if you replace it upgrade it there is a replacement kit i dont have the link but i'm sure someone else does, also a 180 thermostat swap will help
Old Feb 12, 2007 | 01:15 AM
nuch's Avatar
nuch
Thanks, that's what I was afraid of. Anyone have that link, since I am kinda lazy?
Old Feb 12, 2007 | 06:19 AM
ShakyJay's Avatar
ShakyJay
I would gues it is the plenum also. Dodge test procedure is with engine warmed up to pull hose off the air cleaner and hook up vacuum gauge, pull hose from pcv and plug hose and pvc start engine and run at idle for about 30 seconds if there is vacuum then plenum is bad. They also state that it is normal for pressure to build due to some blow by but do not let get above 3 lbs. during procedure.
Link to replacement parts for plenum:
http://www.hughesengines.com/partDet...p?partID=11698
Old Feb 13, 2007 | 06:35 AM
nuch's Avatar
nuch
Thanks for the info and the link
Old Feb 13, 2007 | 06:39 AM
Zachtk8702's Avatar
Zachtk8702
Hey, I also have the 5.9L 360...Mine doesnt knock as much.... But if I try to pull something, or I get going on the interstate I can here it pinging..knocking around...whatever you wanna call it... Thats the gasoline... Im pretty sure any V8 needs premium gas.... But, if you try to run regular unleaded in your 360 it will do the same....
Old Feb 14, 2007 | 08:44 PM
nuch's Avatar
nuch
I thought about gas, the owners manual says regular unleaded is what is best to use I believe. I guess it couldn't hurt to put some premium in there next time I fill up.
Old Feb 14, 2007 | 09:36 PM
TMS Bill's Avatar
TMS Bill
Running premium is a waste of cash. Find out what's causing the pinging. Leaking plenum gasket, too hot plugs, cc carbon buildup, plug wires cross firing ... among other things.
