torque converter lockup problems
Old Feb 13, 2007 | 09:57 PM
DevaRoh's Avatar
DevaRoh
Default torque converter lockup problems
hey there all, i have done a couple of searches and no luck finding a similar problem to what i have.
here is my issue, when im driving my 95 ram 1500 5.9 4x4 and the tranny is cold, i reach 45-50 and the converter locks up fine and even on the highway at higher speeds, if its still cold, it locks up. when it gets warm and i drive around town or highway it doesnt lock up and i can watch the tranny temps just rise and rise and only fall when i am very lightly on the gas or off the pedal all together and just coasting.
i haveread something like this in the searches i found, saying something about the tps being bad or the tranny temp sensor acting up. could one of these be my issue and a quick simple fix or am i looking at something more serious.
Old Feb 14, 2007 | 03:13 AM
DevaRoh's Avatar
DevaRoh
Default RE: torque converter lockup problems
anyone??? im thinking maybe the tps after driving tonight and noticing when i would get up to around 50 or so with the converter still unlocked and then just pull my foot right out of it, the rpms would drop to where they would be if the converter would lock and then instantly shoot right back up a couple hunderd rpm's
does this sound right to anyone?
Old Feb 14, 2007 | 11:02 AM
DieselDemon's Avatar
DieselDemon
Dirty/bad TPS, bad/misadjusted brake light switch, and make sure the grounds are intact. Battery cables connections, body panel grounds, etc.
Good luck with your ride.
Old Feb 15, 2007 | 01:10 AM
DevaRoh's Avatar
DevaRoh
thanks ill look into those this upcomming weekend when i get it up in the air to change the tranny, transfercase, and diff. fluids. also plan on resetting the bands on the tranny. just put the truck through the first hell of the season...first big snow storm here in New England this winter
