gutting my cat
Old Feb 14, 2007 | 03:08 PM
rubemeyer's Avatar
rubemeyer
Default gutting my cat
i was looking to gut my cat today, cause its blocked up and causing problems. i talked with a friend of mine who said he took his out, cut the bottom off and pulled all the combs out and re welded the bottom. i cant quite figure out how to take my cat out without cuting and welding the pipes back together, which is more work than i wanted to do. i was hoping that someone out their who has gutted their cat could help give me some advise on a simple gutting proces. that and searching about gutted cats, some posts said that their check engine lights didnt come on after gutting it. is that cuase their O2 sensors just arnt good anymore and not picking up on the lack of convering exaust orwhat?
thanks.
Old Feb 14, 2007 | 05:05 PM
1996Ram318's Avatar
1996Ram318
Default RE: gutting my cat
I did cut the pipes and weld them back. Its not that bad though, not even a full afternoon of work.
Old Feb 14, 2007 | 05:16 PM
shnormo's Avatar
shnormo
Hahaha that honeycomb that was pulled out is all poisonous. DON'T DO IT
Old Feb 14, 2007 | 05:47 PM
1969roadrunner's Avatar
1969roadrunner
It's poisonous? I'm gonna have to call bullsh!t on that... It should just be charcoal or something similar... Prod it out with a stick if you're scared of it...
Just be aware that your O2 sensors are not going to like you after this and you are going to get lots of "Catalyst Effenciency Below Threshold" codes... No problem, but kinda of annoying...
Old Feb 14, 2007 | 06:07 PM
Cereal Killer's Avatar
Cereal Killer
It must be nice to live in a state with no emission inspection. Pennsylvania sucks.
Old Feb 14, 2007 | 07:23 PM
red98ram's Avatar
red98ram
MAINE SUCKS ALSO, all these lift laws and emission laws, its gay
im not sure about the inside of the cat being poison but i have herd that some have espestis<spelling> which is a cancer causer but just dont touch it with bare hands and dont breath the crap in just take it out with gloves and then trash it...
Old Feb 14, 2007 | 09:03 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: 1969roadrunner
Nope ... not charcoal ... precious metals ... according to Wikipedia:
The catalytic converter consists of several components: [ol][*]The core, or substrate. In modern catalytic converters, this is most often a ceramic honeycomb, however stainless steel foil honeycombs are also used. The purpose of the core is to "support the catalyst" and therefore it is often called a "catalyst support". The ceramic substrate was invented by Rodney Bagley, Irwin Lachman and Ronald Lewis at Corning Glass for which they were inducted into the National Inventors Hall of Fame in 2002.[*]The washcoat. In an effort to make converters more efficient, a washcoat is utilized, most often a mixture of silicon and aluminium. The washcoat, when added to the core, forms a rough, irregular surface which has a far greater surface area than the flat core surfaces, which is desirable to give the converter core a larger surface area, and therefore more places for active precious metal sites. The catalyst is added to the washcoat (in suspension) before application to the core.[*]The catalyst itself is most often a precious metal. Platinum is the most active catalyst and is widely used. However, it is not suitable for all applications because of unwanted additional reactions and/or cost. Palladium and rhodium are two other precious metals that are used. Platinum and rhodium are used as a reduction catalyst, while platinum and palladium are used as an oxidization catalyst. Cerium, iron, manganese and nickel are also used, though each has its own limitations. Nickel is not legal for use in the European Union (due to nickel hydrate formation). While copper can be used, its use is illegal in North America due to the formation of dioxin.[/ol]
Old Feb 14, 2007 | 09:11 PM
97Ram2500's Avatar
97Ram2500
A friend of mine just took the back pipe off got a long 1/2" extention and just started hitting it with the impact wrench, once he was done he just started it up reved it a few times and blew out all of the chunks, then put it back together. Worked good for him..
Old Feb 14, 2007 | 09:27 PM
red98ram's Avatar
red98ram
haha sounds kinda funny, didnt anyof it get cought in the muffler?
Old Feb 15, 2007 | 01:30 AM
Instigater's Avatar
Instigater
Just a fewtechnical notes: 1) Asbestos and 2) He put it together AFTER he blew it all out!
