what fan to use
Old Feb 14, 2007 | 08:24 PM
bigbill7501's Avatar
bigbill7501
Default what fan to use
Hey guys want to get rid of the belt drivin fan want to go electric but do not know which one to use any help would be nice let me know if i can get the stuff at local parts stores thanx
Old Feb 14, 2007 | 10:09 PM
mcss8541's Avatar
mcss8541
Default RE: what fan to use
SummitRacing.com, Jegs.com, Quadratec.com, 4wheelparts.com, Alloutoffroad.com;I installed an electric fan in my 97 Jeep Wrangler Sport 4.0 and it helped out alot. I just recently bought a 1998 Ram 1500 Sport 4X4 and is looking to do the same thing. These websites should help.
Old Feb 14, 2007 | 10:26 PM
Dodge ram it's Avatar
Dodge ram it
For fitment/proper size I contacted Flex a Lite on their tech support line. The tech answered all my questions and I ended up getting all the right stuff the first try, worked perfect too. Good luck, and pls post what you end up using.
http://www.flex-a-lite.com/auto/html/contact.html
800-851-1510
Main Office: 253-922-2700 â–ª Fax: 253-922-0226
P.O. Box 580, Milton WA 98354
Old Feb 14, 2007 | 11:00 PM
Ram1500Dodge's Avatar
Ram1500Dodge
go to the junk yard and get the e-fans from a 99 or newer ford windstar..i paid 13 bucks for mine and they work just as well as the ones from summit, jegs and othe vendors for a lot cheaper...if you want pictures and what not, let me know and ill get you some before you decide to shell out big bucks for the big name fans
Steve
Old Feb 15, 2007 | 11:57 AM
HankL's Avatar
HankL
When considering an electric fan mod
check out your alternator capacity
Old Feb 17, 2007 | 02:32 AM
tmills65's Avatar
tmills65
Ram1500Dodge, I am looking at using the Winstar e-fans in my 1500. What thermostat module did you use? Do you have any pics/details you can send?
Thanks,
Tim
96 RAM 1500 Sport 4x4
Club Cab
5.2L
Old Feb 17, 2007 | 02:37 AM
TPSDODGE's Avatar
TPSDODGE
go to a jeep dealer and ask to buy a f25 recall fan its the fan for the new 4.0 and 4.7 in the grand cheeroke they can be made to fit as a pusher and move more air than you would ever need and they cost less than 50 bux
Old Feb 17, 2007 | 02:44 AM
sirhannick's Avatar
sirhannick
I retro fitted a Flex-a-Lite Monster fan onto my ram and it's a beast. Way more than enough cooling power. I designed my own custom brackets as well as a way to mount a coolant catch can and wind sheild fluid can. People are always shocked to see how much room there is between the engine and the fan. I can stand in there to work on my truck.
If there would be some interest in the brackets I would consider making a batch. They're designed on CAD and made out of Aluminum. I will get some pics if someone PMs me.
Old Feb 17, 2007 | 04:01 PM
junkman306's Avatar
junkman306
ORIGINAL: TPSDODGE
Sounds like a fairly decent deal. Has anyone seen gains? I know there will be, but how about mpg?
Old Feb 17, 2007 | 06:37 PM
Ram1500Dodge
the thermo module i used was from a auto parts store...cost me 20 bucks and was extremely easy to wire up...ill get some pictures up later this afternoon
